How do I program P25 conventional?
Anderegg
Enter text in this field
San Diego
I obviously don't know what i am doing, because the P25 conventional with NAC I put in just comes in as raw static when receiving digital traffic.
Paul
N6ML
On D2, add to the conventional frequency list.
On D3, create an item with Protocol Type "P25 Conventional".
On D4, create talkgroups of interest (populating the P25C TGID column). If you don't know, of don't care about, the TGIDs, create a wildcard item with P25C TGID of 65535 (decimal).
On D5, create a knob position with Receiving Mode of "Monitor Mode", select the conventional frequency and protocol type you created above. Enter the NAC if you know it, or 7FE if you don't. Select your talkgroups at the bottom.
I think that should be it....
picscan
CA
So programming all of these new CHP frequencies in would work same way? Can I set them to scan on one knob position? I'm confused, do I just ignore TX? (Some of these NACs I just made up for examples)
Channel NameTX FreqRX FreqNAC
1VRS1769.16875799.16875DAD
2VRS2769.18125799.18125DAO
3VRS3769.19375799.19375DBC
4VRS4769.21875799.21875DB0
N6ML
TX freq is what you want. RX would be the input to the repeater.
You'll have to program a separate knob position for each channel, then another knob position to scan across them.
picscan
CA
Thank you!
Anderegg
San Diego
I am stuck at D4 with an error saying protocol type no setting.
Paul
N6ML
Go back to D3 and edit the Protocol type - click on "No Setting", and it'll change to a drop-down menu, where you can select "P25 Conventional". Change the Protocol Alias to something like "P25C".
Anderegg
San Diego
Ugh, got it...these things are so unintuative...I can't wait to bang my head against U3 PPS when my radio arrives from Taiwan...
Paul
floridafuzz
Hope, RI
Hi N6ML-
New user here and I could not figure out how to program a P25 conventional system into my G5. I followed your directions and they worked perfectly. I am now able to monitor the Cranston PD on my G5. Thank you so much for your detailed explanation. I am learning more and more every day about the G5. Thanks again!
