Since we seem to get many questions on this topic, let's use this thread as repository of information relative to the thread title. I plan to make this a "sticky".
In the United States of America, the Amateur Radio Services (ARS) is regulated by the Federal Communications Commission as a wireless telecommunications service. The FCC requires that you have an amateur radio license in order to transmit in the ARS. You do not need a license to own amateur radio equipment or to listen to amateur radio frequencies, but you do need a license to transmit. The FCC makes the rules for amateur radio, issues the licenses, and, sometimes, enforces the rules.
The FCC currently issues licenses for three different amateur radio classes of license:
The tests for these licenses build on the other. You must take and pass the Technician license test before you can take the General license test. And, you must take and pass the General license test before you can take the Extra license test.
The question and answers, known as question pools, for all three license classes are available in book form and online.
The amateur radio license tests are administered by amateur radio operators who have qualified to be Volunteer Examiners. Test sessions are usually sponsored by a local club and the VEs work through a Volunteer Examiner Coordinator. A list of VECs can be found here. When you take your test, the VEs at your test session will forward the results to their VEC who will transmit the necessary information to the FCC. Some VECs do this task faster than others. As a result, its possible that if you take a test on a Saturday, that your license and callsign will be issued on Monday. Though not all VECs process test results this quickly, so there could be some delay.
The VEs who administer the tests are allowed to charge up to $15.00 as determined by their VEC. Some VECs don't charge anything. Some charge the full $15. This fee is to help the VECs and VE team offset the costs of administering the tests. The fee does not go to the FCC.
Starting sometime this year, the FCC will start charging $35.00 for new or modified licenses. This is a new decision and we don't know exactly how it will be handled.
Also, starting in June 2021, the FCC will require that you provide them with your email address.
Most amateur radio operators highly recommend that you study for the test before you go to the test session. And, they recommend that you try to understand the material rather than just memorize the answers. The question pools have 300 to 500 questions, so memorizing all the answers will be a lot of work. But, if you understand the material, you should be able to work out the answer. Many local amateur radio clubs offer amateur radio license classes where the test material is discussed.
There are several websites that provide online practice tests or drills. HamStudy, HamTestOnline, and HamRadioPrep are three such sources for practice tests, but there are others.
The American Radio Relay League (ARRL) and the W5YI Group publish study manuals. You can find listings of their publications here:
You may be able to find these books at your favorite online book dealer. But, make sure you are getting a current copy.
Traditionally, amateur radio license tests are conducted in person. The VECs mentioned above usually maintain a list of test sessions and I suggest you check with them for a session in your area. Starting this year, with the COVID-19 restrictions, the FCC has allowed some test sessions to be conducted online. I don't have any experience with the online test sessions, so I'll let someone else describe how they work.
- Technician -- this is the easiest license to get as you only need to pass a 35-question test. This license will allow you to use any of the amateur radio frequencies or modes above 30 MHz and allows some very limited privileges below 30 MHz.
- General -- this license also requires passage of a 35-question test. This license allows you to use almost all of the amateur radio spectrum, as defined by the FCC.
- Extra -- this license requires passage of a 50-question test and it allows you to use all of the FCC-defined amateur radio spectrum
