DSDPlus How to make DSD+ work in 2023(RTL-SDR)
Red_Ice
Since this thread deals with the topic of DSD+ user manuals, can anyone tell me if there is a way to hide the 4 DSD+ windows? The cmd window is easy to hide, but the other three windows I've only managed to minimize.
Red_Ice
Ok, thank you very much for your help, I am trying to show all the DSD+ information in a table and the effect of opening and closing windows is not very nice and, on the other hand, I try to have as few windows as possible to clear the desk
stlouisx50
Mountain Grove, MO (Texas County)
I am trying FMP as well, but keep getting
Initiating TCP connection to 127.0.0.1:20001...
TCP connect error = 10061
[No connection could be made because the target machine actively refused it]
What version of DSD+ are you using, free or FL?
Are you using a SDR? If so, how many?
Did you create/edit the FMP24.cfg file?
Is your SDR plugged in?
Did you start FMP before starting DSD?
Please read this post as well...Reading through this whole thread will help you.
stlouisx50
Free version
SDR-RTL v4 - 1 qty
Have not edited FMP24.cfg I don't know anything about that.
SDR-RTL v4 - plugged in
I have tried starting FMP first as well as DSD and get:
FMP rev 1.4t
FMP -h for help summary
SDR sampling rate = 1.008 MHz
Spectrum window width: 512
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000
DSD+ path: '.'
Primary frequency list: '.\FMP-FreqList.csv'
Secondary frequency list: '.\FMP-FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Audio output device #1 = 'Speaker (Realtek(R) Audio)'
Audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
SDR device count=2
usb_open error -12
Can't open RTL SDR device #1
Opening DSD+ first I get:
DSD+ 1.101pt
DSDPlus -h for help summary
Appending synthesized audio to file 'DSDPlus.wav'
0 frequency records loaded
0 radio records loaded
0 group records loaded
0 site records loaded
0 network records loaded
audio input device #1 = 'CABLE Output (VB-Audio Virtual '
audio input device #2 = 'Microphone Array (Intel« Smart '
audio output device #1 = 'Speaker (Realtek(R) Audio)'
audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
audio input device #1 (CABLE Output (VB-Audio Virtual ) initialized
audio output device #1 (Speaker (Realtek(R) Audio)) initialized
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Mono audio decoding initiated; press Esc to exit...
but If I try to open DSD+ first then FMP I get the same FMP error, but it auto closes out.
Did you read the post in the link I sent? It probably has to do with the firewall/security software.
stlouisx50
Yes, I turned off the firewall and still no luck.
This is what I get when I click the AUTO file
DSD+ 1.101pt
PDXh0b0
Woodland, WA
Trying create your situation, only way I get it is running dsdplus-fmp.bat
Try running just the fmp.exe
PDXh0b0
Woodland, WA
With the v4
stlouisx50
Just clicking fmp application =
FMP rev 1.4t
FFT size: 32,768
DSD+ path: '.'
SDR device count=2
usb_open error -12
PDXh0b0
Woodland, WA
Regardless, with the wrong .dll you should get static, make sure everything is closed, only that dongle plugged in, run fmp.exe
PDXh0b0
Woodland, WA
Try opening FMP-CC.bat with a text editor (like notepad)
Edit it to
FMP -i2 -o2 -P0.0 -f162.5500
Save it, then run the FMP-CC.bat
That don't work..you can message me if you'd like to use teamviewer
dnesteryuk
I am also using SDR-RTL v4, but after replacing rtlsdr.dll from Release.zip I got this error.
Error
Unrecoverable error encountered:
Exception number = 0xC0000005 (Access Violation)
Instruction address = 0x23A40F7
Action: Read of address 0x3A44B (238667)
Register dump:
DS: 0000002B CS: 00000023 IP: 023A40F7 EAX: 0040EB00
ES: 0000002B SS: 0000002B SP: 0019FAE0 EBX: 00000000
FS: 00000053 Fl: 00010206 EBP: 0019FB50 ECX: 00489768
GS: 0000002B ESI: 0019FB60 EDI: 00402000 EDX: 00000000
[Press Ctrl-C to copy this text to the clipboard]
OK
Does anyone know how to solve it? Thanks
