BCD325P2/BCD996P2: How to program Uniden BCD996P2
dlcharles
Vanceboro, NC
Rookie owner, been trying to understand how to program to scan. Played with the freescan software but still totally confused. Any guidance would be greatly appreciated.
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Proscan is a much better app for programming, still supported with regular updates & its developer is an active & responsive member here on the forums. Freescan abandoned their project back in 2015 so thus support for the 996P2 is "experimental" as noted on their website.
hiegtx
Mentor
Dallas, TX
Since you are a Premium Subscriber, you can use FreeSCAN to import systems & their related information into a programming file on your PC.
There is a user guide for FreeSCAN in the Wiki:
FreeScan User Guide - The RadioReference Wiki
ProScan has many more features than FreeSCAN, and can also import directly from the RadioReference database. However, FreeSCAN can handle what's in the database for your county.
While there are a couple of talkgroups on the statewide system, Viper, for the county Sheriff's department & county fire, it appears that most of the agencies use conventional channels, not a trunked system.
MILCOMM
FEMA Region 3
I have used ARC XT programming software for both Trunking and Conventional systems
and has worked flawlessly. I have also programmed rcvrs manually. It takes longer but
you don't have to connect your radio to a computer. Just do it. Practice makes perfect.
Don't worry, you won't hurt your radio if you make a mistake. You can just erase everything
and start over!
tvengr
Well Known Member
Baltimore County, MD
Give this FreeSCAN file for Craven County a try. First, you will need to install the driver for your scanner. Save the attached zipped file to your computer and extract. Connect your computer to your scanner. Open the extracted file with FreeSCAN. Go to the Scanner tab and click on Upload Programming. Highlight Erase All Systems & Settings. Click on Start Upload. There are 3 systems. The first has the conventional frequencies for Craven County and has a system quick key of 1. The second has talkgroups for the VIPER statewide trunked system and has a system quick key of 2. The third is the trunked system for New Bern and has a system quick key of 3. Pressing 1, 2, and 3 on the keypad will toggle each system on and off. The attached PDF file has instructions for using quick keys. The groups on each system can be toggled on and off to select the frequencies or talkgroups you want to monitor. Set squelch on the scanner at 2. Please let me know if you have any questions. Quick keys as follows:
SYSTEM QUICK KEY:
1. Craven Co Conv
GROUP QUICK KEYS:
1. Craven Services
2. Craven Fire/EMS
3. Craven EMS/Hosp
4. Craven Law
SYSTEM QUICK KEY:
2. VIPER Craven Co
GROUP QUICK KEYS:
1. State Events
2. State Interop
3. State Emerg Mgmt
4. Prep & Readiness
5. State Natl Guard
6. Helo&Aqua Rescue
7. Civil Air Patrol
8. Craven County
9. NC St Hwy Patrol
SYSTEM QUICK KEY:
3. New Bern NC
GROUP QUICK KEYS:
1. NewBern Services
2. NewBern Interop
3. NewBern Fire/EMS
4. NewBern Police
5. CarolinaE Health
  • Craven Co NC FS.zip
  • Uniden Scanner Quick Key Instructions DMA.pdf
mscir
Santa Cruz, California
The linked Freescan user guide contains a link that is not working
> (A paid subscription to RadioReference is required to use the following features: )
At 3:20 after entering your location you show all of the "Available Systems", where can we read about all of them to see which ones we want? My tendency would be to download all of them for my location, but I'd like to research that. Also if we do want frequencies from more than one system, do we have to do each download then scanner install separately for each individual system?
mscir
mscir
Good to know, thanks. Would you mind summarizing the features you like better in Proscan? I'll look for YT videos about it as well.
Chris0516
Pittsboro, North Carolina
Personally, I like Proscan over Freescan, for a number of reasons.
1. Proscan still has developer support, whereas. The developer of Freescan pretty much went AWOL years ago.
2. Proscan supports more scanner models, than Freescan ever did.
3. The $50 price tag of Proscan, that some people whine about. To me, 'is a drop in the bucket'. Just because Freescan is free, it doesn't anywhere near, the number of features that Proscan has.
4. Freescan is like a Volkswagen Beetle. :( Proscan is like a $2.5M Bugatti Veyron Super Sport.:)
mscir
High praise. I'll have to find videos on how to use it to appreciate what it offers. Thank you.
