How to use the programming software
Novix
Hey folks I'm new to the programming part of things here and I have tried to google all the info I can plus you tube and on and on. I have seen nothing that gives me a good look at how to program my vx-2500 using ce52 or ce52e ... Does anyone know or have a link for a tutorial on using this software? I have everything I need just not the walk through on the process.
MBill
First there are two different software packages. The CE52 does the VX2500U/VX3200. The CE47 does
the 2500U(A), (C), (D), (F) models. Assuming you have the correct software the next step is to
determine whether you need the radio on before you try to read from it, or the radio needs to be off and
then turned on for reading. I don't recall which method works with the VX-2500U. Start up the software and
select "Radio".On the drop down menu select "Read". If you get a "time out" or other error message during
the read process, try the other method. Which ever one works you should see some sort of progress bar as
the radio is read.After reading its basically a matter of clicking on the column you want to change and using the
space bar to run thru the selections for that column. You can select or deselect a channel by
clicking on the channel number and hitting the space bar. Grey-out means radio skips this channel,
hit space bar again and channel is in active list.
Note if you have just one channel programmed and you want to add a channel(s), select "Group"
from the main menu and select "Channel allocations..." You can then type in the number of channels
you want in Group 1 (or 2 etc.). The drop down "Help" menu will give you more information on each
selection. When finished, select "Radio" and click "Send to Radio." Hope this helps to get you
started.
Bill
Novix
Thank you Bill for that info, I have the 2500v and was looking at programming some CB channels into it as well... One of our radio shop guys here in town said that I could... Not sure if that was a line or not but like I said I'm new at this...
Thanks again
MBill
VX-2500V
Not that familiar with the V series. Seems to be some difference in frequency band coverage
from other sources. One source says it is a dual band radio, covering 134 thru 174 Mhz., and
450 thru 490 Mhz.
Another source only shows it as 134 thru 174 Mhz. Either way, it won't cover the CB band
down at 26 Mhz.
Maybe the guy at the Radio Shop was thinking of FRS or MURS in the UHF band.
Whether your new or old in radio world, this is a great site to learn more about radios.
Bill
Novix
Ya I've been reading a lot... very good site. Thanks for the insight
