HP-1
krafty
hello everyone .im new to the forum i have a question about hp-1
i bought the scanner new a few years ago and am now just noticing that i cant receive channels out side of my city.there is a much larger city 15 min drive north of me and i cant get not even one frequency from that city at all nothing.im on the 3rd floor of apartment building well above house tops. i should be able to get the channels from that city.so i put the scanner to a test.my mom has a old 1980's scanner we put them side by side she can get channels i cant from that city.whats going on? ive tried squelch its set at two bars.moved the range for 30 to to 1.5 miles nothing helps. i have version 2.05 whats going on with this thing??
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
A couple of things:
1. When is the last time the frequency database was updated? Could the other city you want to hear have changed frequencies?
2. Are you using the stock antenna? The stock antenna is known to be pretty weak, and an external antenna with greatly improve the scanner's performance.
W8RMH
Feed Provider Since 2012
Is it scanning their frequencies and just not receiving them or is it not scanning them at all?
Are these channels in the RR database? If you don't see them in the scanner you can try to program them into a Favorites List.
Make sure Service Types are selected and the channels/systems are not avoided.
It is unlikely that the HP-1 can not receive the signals if the other scanner is. It is probably program or setting related.
PBman
Missouri
Mine does the samething won't hardly pickup anything but very close range and if you turn on the ATTN button can't even pickup close range I hope there is a way to fix that.
mule1075
Washington Pennsylvania
If you are using the stock antenna replace it.The OEM antenna that it comes with is terrible.
Sent from my Z750C using Tapatalk
PBman
Missouri
Using a diamond discone D-130NJ antenna with LMR-400UF coax, mounted 30 feet up, all my other scanners pick up towns 10 times further on that same antenna.
krafty
hp-1 antenna
whats the best replacement antenna for the hp-1
MStep
New York City
Worst performing scanner I have ever owned bar none.
Perhaps a defective unit? I've owned receivers and scanners for over 50 years, and while I would not rate the HP-1 as particularly "stunning" in its receive capability, I wouldn't say it was the worst I have ever owned--- if anything, I would call it fairly typical of wide band receivers, with an edge given to it for its touch screen and ease of operation.
Blackswan73
Central Indiana
I have one on a 668, HP2, and 536. I find the antenna adequate for the VHF in my area, which is EMS, and some FD. I can pull VHF mobile and base transmissions from up to 10 miles away. Good enough for my use.
Voyager
Fair enough. I have several. They are outstanding on 800 MHz, pretty good on UHF, worse than the stock antenna on VHF, and forget about Low Band.
Of course location matters, too.
PBman
Missouri
I will stick with what I said about mine being absolutely the worst scanner that I have ever owned...
My BCD996P2 Scanner's however at least for me and my area are much better and I absolutely love them.
krafty
hp-1
what about the miracle baby antenna i was looking at online?
Voyager
Those work poorly on all bands, but will pick up local systems. I use something similar on my 436, as I'm usually interested in the activity where I am at the time.
krafty
im going to reset all setting on the hp-1 and start over again. like i said i cant get not one frequency from the large city 15 min north of me.i can only get my own city.or maybe i just dont know how to use the dam thing. im very upset since it was very expencive and can only reach out 10 km or less in my own city.im going to try another antenna and see what happens if that dont work im selling it.one last chance for the hp-1
Voyager
Make sure all the Service Types are enabled and the range is high enough.
krafty
yes ive done that voyager im getting more stations now. but weak so must be antenna.or something is interfearing with it.ill give it a few weeks and see how i like it
