RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 7,756
I have an very useful, if not antique, HP8920B Comm Test set that has performed flawlessly for decades of occasional use. Today out of the blue I get a display shifted vertically to top of screen. I cannot figure out if it is a problem in the test set or the Omnivision CRT assembly. I did try the Vert Hold as it seems to be the only option and other than messing with sync, I am back at same problem. The only documentation for the CRT monitor I have is a generic Omnivision document. I am really trying to figure out where to start, the CRT or the test set. The scan rate is odd or I would hook up another monitor somehow. Thanks Joe
This (example) is all that I can see on my screen and it is shoved all the way to top of the screen. There is something out of whack. No distortion of the display (looks ok, maybe a bit small?) and I just discovered this today after months of the unit just sitting there. I cant see any error codes because those usually pop up at top of the screen. I reseated the controller and CRT driver in the test set to no avail. The bottom picture is what should be displayed.
1) The problem: and 2) What it should look like:
