HPD Data Field Format
RalphHolden
Allen, NC
Does someone have the file structure & field definitions for HPD files?
I have a lot of data that I plan to format using a spreadsheet & then save to an HPD file for HP436/536.
I've attached a screen shot of a sample file.
jonwienke
More Info Coming Soon!
VA
Forget that mess. it's not publicly documented (at least not officially).
You can create a favorites list in Sentinel, and copy & paste from Excel to Sentinel.
RalphHolden
Allen, NC
Sentinel is fine & dandy for making simple favorite lists. What I am attempting to do is a bit beyond the capabilities of Sentinel which is why I asked for the file structure of the HPD file. My master list is derived from the FCC database. My "mess" will be all my local stuff with lat/lon entered so I can use location based scanning. It's a major pain to keep switching screens to enter coordinates.....Guess I'll have to figure this out for myself.
jonwienke
VA
No it's not beyond the capabilities of Sentinel.
You have Systems and Departments in Sentinel. You enter GPS coordinates for a Department by clicking on the Department in the Favorites List editor, then going to the Location tab.
You can probably create 90+% of your favorite list by using the "Add Channels On Range" tool in Sentinel. Specify your location, the Service Types you're interested in, and a Range setting, and it will put everything that matches in the Favorites List of your choice. Generally the easiest way to use this is to have a high Range value, then manually delete anything you don't want or can't pick up. It takes less than 5 minutes total, no looking stuff up manually required unless you're monitoring some really oddball or secret squirrel stuff.
ofd8001
Louisville, KY
As best as I can tell, Uniden is using something like a relational database with a number of tables and master index file. I imagine that there is at least some degree of copyright stuff involved too.
I suspect that unless you are very well versed in this kind of thing, you might be taking on an awfully big project.
If it was me, I'd use the "regular" Sentinel database. Anything you might discover from FCC records that isn't there could be added as a Favorites List.
jonwienke
VA
Also, most stuff in the master database is already tagged with lat/lon and service radius, specifically to enable location-based scanning. You're trying to reinvent the wheel for most stuff.
ProScan
Software Provider
Ontario, Calif.
File structure is plain text and tab delimited as you may know.
To discover what the field definitions are, I would change the parameters in Sentinel and then save the file then look at the file to see what changed. The field definitions are different depending on col A if it's a Conventional, Trunk,Site, C-Freq, T-Freq, etc...
jonwienke
VA
Actually, HPD file is NOT plaintext. It uses some kind of compression, and you see very little English looking at it in a hex editor.
ProScan
Software Provider
Ontario, Calif.
I'm looking at E:\BCDx36HP\HPDB\s_000000.hpd and E:\BCDx36HP\favorites_lists\f_000001.hpd. Those are plain text. What files are you looking at?
fxdscon
¯\_(ツ)_/¯
HPD files are indeed plain text. You are thinking of HPE files.
RalphHolden
Allen, NC
What I am attempting to do is import all the non-public safety stuff that's not in RR database. I'm very well versed in relational databases, etc. This is going to be a weekend winter project consisting of all counties that are in the Charlotte region. I will tinker with it as suggested & see what changes.
phask
zanesville
Suggestion - since yo know what you are doing, use whatever DB you use- run a report as a text file and C&P into Sentinel. I'd still use Sentinel as (if memory is working )- there is a table of the favorite lists and need to keep it in sync.
I used to do a lot of Dbase and other DB, but anymore I'd be lazy and use a spreadsheet :)
FWIW - pretty sure directly creating HPD has been done as well. Way back in the early HP1 days someone did some "stuff".
Obviously Grommert at ARC is doing it.
