HRO Settings
pdaustin
Victoria BC
Hello, I have programmed the following setting into the G5 but not hearing anything on the G5? Would anyone have any input as to what might be going on or not going on?
My radio has been updated to PhaseII
https://www.radioreference.com/apps/db/?sid=7846
I've programmed
System ID 861
WACN BEE00
Using Talkgroup FFFF
Highrock Park 772.08125 & 772.33125
k-9policexj
Portland, Oregon
I think if you look closely at the database under the MODE section the letters DE appear behind all the talkgroup id's. I have a feeling that the system being used/trying to monitor is encrypted. the D is stands for digital and the E for Encrypted.
If i'm correct, this means unless you are an authorized user on the system with a valid key programmed into a radio that affiliates to the system, that would be the ONLY way to monitor... In other words your system is kinda locked down to prevent folks listening in...
pdaustin
Victoria BC
Thanks K-9, I did see that but was hoping it was for the Mainland talk groups and not the Island ones. Oh well. Will have to find another hobby I guess :-(.
k-9policexj
Portland, Oregon
Encripted System
Yeah, I'm sorry about that... encryption has it's place for sure, but it hurts when it kills a great hobby. I'm hoping someone else will chime in here...
Also another thing to keep in mind is the G4/5 needs (I believe) to have TWO main control channels programmed in... You can have the alternate ones programmed in, but I think it needs another main frequency. Try doing that first before giving up hope!
Ryan in Portland, Or
