HT1250 CPS Error 9
JGK101
Newport, R.I.
When attempting to read my HT1250 (AAH256DF9AA5AN) CPS Version R05.02.04 running on an Intel i5 1.6 Ghz, Win 10 laptop I get the message "Error 9, No response received." Radio is on with a charged battery, com port is correct. This is the first time trying to read this radio. Any guidance would be greatly appreciated.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Win 10 is not a supported OS for the Waris series. Try win7 or winXP compatibility mode. It also may not play nice with 64bit OS
JGK101
Newport, R.I.
Kayn, I appreciate your guidance, however I tried the compatibility modes for both Win 7 and Win XP without success. I set the com ports as each version wanted different port (4 or 5). Perhaps the 64 bit OS is the culprit as you suggested. I don't know if I have a 32 bit machine anymore. Any other possible solutions? I have never had these problems, though it has been a little while since I have used CPS.
Giddyuptd
Here and there
As said it is the OS and the 64 bit machine.
It's handy to have a 32bit older one around for equipment they are pretty cheap on flea bay.
Also handy if you're into the way older lines to have a true dos windows 3.1x around.
IAmSixNine
Dallas, TX
Double check your radios accessory connector.
My warris radios were always prone to have dirty connectors. Cleaning them off usually resulted in correct reads.
I was also using an older/ slower computer and DB9 connector with smart rib.
mm
oregon
I program all of my 220MEG 1250's and my UHF CDM's on a 64 bit machine but not above win8.1 with no issues.
This sounds to be a CPS win-10 and a CPS usb driver incompatability issue more than a pc 32/64 bit issue.
deanq
I run the software on an up to date WIN 10 machine with no issues. Use a cable with an FTDI chipset.
MWW85
NJ
Double check your drivers match your cable. Look for a FTDI usb driver or a Prolific 3.2.x.x based on your cable.
SpugEddy
Camden County South Jersey
I'm using Windows 7 64 bit and have no problems.
You MUST USE Prolific 3.2.0.0 as MWW85 said. But
I can almost remember hearing that R06.12.05 & .08
both have issues with Windows 10. I use R06.12.05
