HT1250 Programing
firephoto20
California
I need a Codeplug written into my HT1250, I can edit the code plug but it wont let me read or write my radio. can someone PM me and give me an estimate on how much you would charge to do it ?
C138NC
Tactical Taco Consumer
NC Taco Command
C138NC
NC Taco Command
What does that do ? There is no download links that I can see....
youll have to register before you can download anything.. forgot to mention that to ya
I would however make a backup of your previous codeplug just incase
firephoto20
California
I have the code plug I want...my software just doesn't work so I have to have someone write it....never been to any radio shops around here I don't even know if there are any around here..
C138NC
NC Taco Command
Where in california do you live at?
I can look around and call but could it be that your CPS is out dated?
mancow
N.E. Kansas
You can't just write a codeplug to a 1250. It won't work because of the serial # mismatch.
Also, you say you can edit it but you can't read or write. What is it that you are editing? Is it a file that was previously read from the radio? If not, what are you editing if you can't read or write the radio. I am confused.
Do you have any additional details about the problem? Are there any errors displayed on the PC?
firephoto20
California
I got the newest version of CPS (I THINK-CPS R06.10.04) but it still wont read my radio.....any suggestions...I'm using a RIBless DB9 connector cable....
mancow
N.E. Kansas
Is it a factory Motorola ribless type cable? You said it's a DB9 so I assume not.
The Chinese ribless cable quality is nothing to relied upon. I have two Astro25 cables that only read on certain radios. I have no idea why.
You might try popping the DB9 cover to inspect the solder joints. Be prepared to be scared by the horrid soldering job. Inspect the whole thing while you are in there and then maybe take a look at the radio end too.
It sounds like your software is not the issue and the radio firmware should not matter.
terminus
New Mexico
Just look through the LA directory for radio shops and call and ask if they can do it for ya, they shouldnt charge ya so much for it
Alot of people won't do this because radio techs or shops will ask them questions or demand to see proof they are authorized to set up to transmit on those frequencies.
C138NC
NC Taco Command
Yeah thats right, unless he gets a letter from the chief since hes a fire explorer and volunteer. So thats all over in LA so i have no idea how they run business down there.
