HT1250LS question
NJEMT12982
NJ
I have an option to purchase a HT1250LS radio at a really good price. I will be using it for UHF conventional within the 450-512 range for work purposes. I am reading that there is only a max of 16 conventional channels which is fine for work but I am curious about the remaining 128 trunked channels it says it can handle. Does this mean I can have my conventional frequencies put in and on top of them a UHF trunking system? (Not that I need one)
michaelstephen
Yes. You can have the 16 conventional, and the 128 trunking on top of it.
Skypilot007
Medford, NJ
If you do not need the trunking I would be looking for a non-ls version of the HT1250. Those 128 trunked channels can only be use for trunking channels. So you're stuck with only 16 conventional channels as opposed to 64 convention channels on a non-ls radio.
nhfdcadet
CETsr
New Hartford, Ct
skypilot what is the difference between LS and LS+? i have seen some radios with and some without the +, also have seen some that have XLS
motocomm
Cincinnati, OH
xls is probably the ht1550. I believe the difference is the type of trunking system the radio will do.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The XLS is part of the Commercial Series CP200 product line and not the Waris HT1250's and 1550's.
Edit to add.....
My error here. There is a HT1550XLS model. It was a Conventional/LTR radio with 160 channels. (The CP200XLS was much more commonly seen.)
In general, the LS models are Conventional/LTR while the LS+ radios are Conventional/PassPort.
Before purchasing any radio, obtain the model number and look it up to be sure that it has the features wanted.
motocomm
Cincinnati, OH
All of the 1550's ive seen tend to have XLS at the end of the number. Not sure if there is a 1550 without the XLS or not.
nhfdcadet
CETsr
New Hartford, Ct
yeah my 2 1550s have xls, ive seen an ex600xls, wasnt sure what the difference was between them all
Skypilot007
Medford, NJ
Sorry but I do not know the difference. I stay away from the LS versions as I have no need for the trunking options.
SteveC0625
I said it earlier, but it bears emphasizing in this discussion....
LS or LS+ or XLS or plain is not nearly as important as verifying the model number and the exact features included the radio. To do that, you MUST have the model number of the unit and then refer to a model number chart. This is the only way to be certain what features are in the radio.
Here's the model number chart for the Professional (Waris) Series portables for North America and Latin America:
Skypilot007
Medford, NJ
Interesting chart. I never knew there was an 800Mhz offering or smartzone option for warris portables.
