ht750 question
Worcester County Massachusetts
hey all, i am new here so go easy on me..
i bought an after market ribless cable.. i know its not a true ribless, but it programs via usb and cps. it is made for the CDM750, i want to modify it to work for the HT750.
the program cable is made to program via the mic port
evfd1625
Indiana
Wirelessly posted (Opera/9.80 (Android 4.0.4; Linux; Opera Mobi/ADR-1301080958) Presto/2.11.355 Version/12.10)
Go to bat labs and look up model specific information and it should show the portable pin out. You will probably need an old speaker Mic or something to connect to the radio.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Before you go chopping up that CDM programming cable, check Ebay for USB programming cables for the HT750, 1250, and 1550. They're always a bunch up there, and it may be cheaper and easier to buy one instead of hunting around for the HT mic connector and then trying to wire it up to work properly.
You can sell off the USB/CDM cable if you don't need it and lower your cost even more.
im gonna retain the cable for now, maybe i can get my CDM to work again. im probably just gonna buy one. i am also looking for ANY information on the black box radio program cable. i had the serial port version, and am looking for a schematic on the device or a schematic for a similar cable. the black box uses the M1 Moto connector.
Bits in the Tip
I believe I have read a time or two that ribless cables have electronics in the plugs that make them ribless. There's a RIB box in the cable. Just making a cable may not work.
cabletech
Puget Sound
The Blackbox cable can be had at ebay for about $20.00. It will also do the HYT and a few other Moto radios.
It can be had in both 9 pin serial and usb.
All USB cables have a mirco TTL converter in them for the specific radio series. It is not easy to 'rebuild' one cable for another radio.
Spend the $18 to $30 for the correct cable. Check kawamall on e-bay I have had very good service and luck with them
