Hytera MD782 Password
Forts
Ontario, Canada
True enough... I was just commenting that flashburn on it's own won't help with newer firmware.
idarlund
Even with flashburn, you aren't going to get too far, dependng on your FW version. After FW 7.5ish (or maybe 8?) the codeplug contents are all encrypted. In older versions the passwork could easily be found in the clear.
I'm not talking about decrypting anything. I'm talking about offline brute-forcing of the password (hash). In almost every case this happens by extracting the hash from whatever stores the hash; AD, /etc/shadow, ROM, or whatever. I also really doubt that Hytera has created it's own hashing algorithm.. so if the password hash is possible to extract, the password hash is possible to brute-force.
So.. Is it possible to get the (hashed) password from a Hytera v9 device?
Those are called proprietary secrets 😁
As stated above. I really doubt that Hytera has created it's own hashing algorithm. Also; there's no point in keeping the hashing algorithm a secret. That's called "security by obscurity". The password(s) people choose are supposed to be strong enough that you can't brute-force it easy ;)
Does that mean it's not possible to get the password hash(es) from a v9 device? Or are you just trying to say that "the password is encrypted and you can't read it in clear text any more"? If the latter; Please let me be the judge of that ;)
Moommoom
Hello W4ADC;
Did you solve your problem? If not, i might help you. You did not mention your firmware version. Anyway there is a tool named flashburn for hytera radios. Unfortunately sharing such tools on this forum is forbidden i think. But you can find it online ;)
1. Download and install flashburn
2. Read "user_defined" data. The result should be approximately 15-16Mb(You need programming cable for this)
3. Send that file to me. I am going to brute force and try to find your pass or reset it.
When you crack open the password, are the the data saved?
slayer23
I very recently ran into this issue. The most easy way to go about this is getting the right CPS and firmware version and doing a wipe.
idarlund
Yes, you could do a wipe. But what if you want to actually read the config which is on the radio? :)
@0xFF1E071F : How do you do the bruteforce and will it work on a v9 dump?
slayer23
That's a whole other topic lol. OP just wants to be able to program the radio.
Tarnish05
DMR Flashburn located - version V5.00.01.003
Cannot read with USB, CPS works fine so I know radio and lead is good.
Could this be a settings change needed in FB or is the above version just for PD782 as showing in the 'set' config file?
Can this FB version be used with any radio?
radioopperator
Is that a good thing I download every version of CPS and firmware I can get my hands on? :)
0xFF1E071F
Did you try reading via "Programming Mode" or "Download Mode". FB only works on "Download Mode". By "Download Mode" I mean "Upgrade Mode".
If you tried on Download Mode and cannot read it, it is most probably a version issue. You should find a newer version of FB.
What is your firmware version?
Tarnish05
Radio is:
FW A7.06.01.006
BL 01.07.004
Last P - 2018
Hopefully FB version is suitable as it took me a while to locate this version - V5.00.01.003.
Based on radio fw version, what version should I be looking for?
Regards.
Tarnish05
Ahhhhh! Yes, success! Managed to read and save the file now. Dropped you a PM with a link to it :)
tog182
Can someone let me know where to download flashburn, I have a PD 685 with firmware version V8.05.06.011 and trying to get the password, as I lost it.
tog182
Thank you for your reply, I have done work on the code plug in the radio and have lost the password for it, and would rather not do all the work again and was hoping to get hold of Flashburn in the hope of getting the password.
motopit
Hello
Can anyone help reset password in pd505. I have a userdata file.
Pit
Tarnish05
Ahh, your correct, and partially wrong. Your looking at the problem the wrong way.. You don't need to un encrypt it. You just need to "Brute Force" it. Flashburn lets you pull the data from the Hytera. Including the password locked file.
This can take 5 minutes, or hours. But its a simple path forward. Its not a high bit encryption. Its a simple encryption. You could write a program in a dozen languages, to force and retry.
Ofcourse, the most simple way. Is matching the CPS to the firmware, and doing a reset. But some firmware versions are not easy to come by.
I sent you a PM on this......
hurricaneoleg
Hello. I need the v9 version of flashburn as well, at least for someone to tell me where to find it, other than "try google" because I have, for weeks now and can't find anything. If anybody has it or knows where to get it please get back to me, I'd really appreciate it tremendously! Thank you.
achalela
Colombia
Hi everyone. I need help! I have two Hytera PD-788G and PD-786G with forgoten read password. I dont need to read actual configuration i only need to made a Factory Reset to reconfigure it but i cant do it.
Today i uprade both to A9.00.07.105.IM with the Terminal Batch Upgrade Subscribe and i have CPS V9.00.09.200IM(EM5), when i try to made Factory Reset i get password error and the same for read it.
What is wrong ir missing? Thanks.
