Hytera MD782 Password
mardian
Bontang,indonesia
Hello! What version of Flashburn did you use to read rcdb_data from your HM788?
I use flash burn version V5.00.01.003 and in reading files. DAT does not appear numbers or letters, only 0 appears, in large numbers.
Do you have a version for hm788?
Thank You
cgservice
Thank You
Flashburn V5.0 can read data only from PD/MD radios with firmware version not higher than 7.0x. Check your PM
W9GIL
here it comes again. got md782i and it is password read/write protected. firmware is A 9.02.02.000. any guidenance will be apreciated.
cgservice
Do you have a Telegram? PM me your contact, I'll try to help
Forts
Ontario, Canada
So... Here is a little trick I've learned. Ever notice that if you do a firmware update on a passworded radio it goes thru just fine? And this process involves reading, updating and rewriting the codeplug as part of the process.
If you sniff and capture all the usb data during this process you can find the password. Take a little knowledge to know what you're looking for, but it's there.
W9GIL
it seems easy if you know what you doin' ;)
KD9FAL
Cape Girardeau, MO
I am also looking for guidance on how to remove the read/write password and push a new codeplug to the radio. I have a MD782 with firmware 9.00.07.105
ireill1
@0xFF1E071F
Longshot, as I've seen you discussing this in forums as far back as 2019. But if you still have the time and interest to brute force a locked Hytera, I've got a PD702 that could really use your attention.
Feel free to contact me at ianreill1@gmail.com too. Thanks.
PaulStorm
Which firmware version?
I'm not sure to be honest how is the best way to find it? I have the programming software but the radio has a read write lock on it :-( the CPS software is version V9.02.02.003.iM.EM5
cgservice
That was a question about the radio firmware version, not the CPS version...
limen
Hello, another MD782 with password protection
So, with A6.05 FW should I bother with flashburn (I can't find it anyway )? Or just upgrade the FW, like follow Just a quick guide on Hytera cps password protection? I do not have the Upgrade kit :/
I have
DMR_SW_CPS_V8.05.06.013_EM5 and DMR_SW_CPS_V9.02.21.000.iM(NA2). How should I proceed?
a2s
limen
Install CPS V6.05 and try "Reset To Default Data".
Thank you a2s. But the CPS is asking for password at setup. Can't evn install it. Please, send me a DM. I can'tfigure out how to sent you a DM.
a2s
You can find the password for installing CPS in SN.txt
