Hytera PD755 - Time Synchronization Error?
m6jxb
Hi there, I wouldn't usually post but can't find any answers to this either experimenting myself or on the internet.
I recently purchased a pair of Hytera PD755's, not my first Hyteras. The first was able to be reprogrammed fine, and the second seemed to be going well however upon attempting to write to the radio is displays a error stating "time synchronization mode convert data error".
I've never come across this error personally and I've programmed many Hytera radios, the internet has also completely failed me on this one. Does anyone have any ideas or suggestions about fixing this or even an explanation of what the error actually means? I am using the latest version of Hytera's CPS (i.e "DMR Customer Programmer Software")
All radio info:
PD755
400-470MHz (UHF)
Firmware version: A7.06.05.002
DSP Version: A7.06.05.002
Radio Data Version: D7.06.02.003
Bootloader Version: 01.07.004
Last Programmed Date 16/8/2016
Thank you to anyone who could provide some help!
krugerpl
I have the same problem with Hytera PD785G. Does anyone have a solution?
Data radio version: D6.05.05.005
Firmware version: A6.05.07.006
CPS: V2.5.18.017.EU5
cgservice
This version of CPS is not intended for your radio.
bjornepappa
I guess you have CPS 2.5.x for the new HM/HP/HR series. This also works for PD radios with newer FW (there is a "before and after v.9"), but with quite a few bugs.
You probably should try CPS V6.05.05.019 or newer, but not as new as 9. Alternatively - upgrade FW to something newer, which will also be compatible with the HM/HP/HR CPS.
