why are you trying to update something that is currently up to date?????????
When looking at Maxims collection of all firmware version available for SDS100 and SDS100E there's no 1.04 versions. Perhaps it's a SDS100 PT or AU or similar that doesn't do updates the regular way, if they actually have any updates available.
/Ubbe
is out of date. there is version 1.10.00 availablewhy are you trying to update something that is currently up to date?????????
how will I do? With sentinel your device says up to date. I could not find the 1.10.00 beta version.Then nazlicafe can download the latest files from Maxims One Drive storage and put those in the firmware folder, as per instruction for the open beta.
/Ubbe
I do not know that I bought this device second hand. He could not find the invoice in the person I bought.Do you have the USA version of the SDS100, or do you have the SDS100E (or any other version)?
.[QUOTE = "fxdscon, gönderi: 3437652, üye: 101354"]
Tarayıcının arkasındaki veya pil bölmesinin içindeki (belki pillerin altında) Uniden tanımlama etiketine bakın. Bu etikette model numarası ne diyor?
[/ALINTI]
I am using version 2.02.01. I did it by following the instructions. However, it did not update the firmware again. old version again. He wrote my frequencies, which are also my sentinel, on the device. Do you think my card may be broken anyway. If my sentences are distorted, I apologize again. Because I am translating from Google Translate..
That certainly appears to be the USA version of the SDS100.
Next question... what version of the Sentinel software are you using? From the top menu bar in Sentinel, click on "Help", then click on "About"
If you are not using Sentinel USA version 2.02.01, download and install it from here:
BCDx36HPSentinel < UnidenMan4 < TWiki
info.uniden.com
Also, if you don't have the SDS100 owner's manual, you can download one here:
Follow the instructions carefully on pages 10 and 11 to update your firmware and database (be sure to disconnect the scanner cable and let the scanner re-boot for the firmware update). Let us know if you can now update.
If you are still unable to update using Sentinel, you may have a bad SD card.
Go to Maxims One Drive where he has all firmware version and go to the SDS100 folder.how will I do? With sentinel your device says up to date. I could not find the 1.10.00 beta version.
Thank you very much for your help. I could not find the place you said. If I ask, can you send a link.Go to Maxims One Drive where he has all firmware version and go to the SDS100 folder.
Download the file "SDS-100_V1_10_00.bin" and "SDS-100_SUB_V1._02_01.firm" and put those files on the SD card in the firmware folder.
When you turn the scanner off and on it will update with the new firmware. Try to have the USB power cable connected to power the scanner if the batteries are not good enough to hold enough power during the upgrade.
/Ubbe
Thank you very much for your help and interest.You are doing very good with the translating.
It seems possible that the SD card may be at fault. Bad SD cards can cause a wide variety of unusual problems.
You should try a new SD card (or re-format the old one). You will need to use the "Clear user data" function in Sentinel on the new (or re-formatted) card before the scanner can use it. The scanner must be in the "mass storage" mode. Be sure to check the "display all drives" box in the clear user data window. Then try to update again. After that, write to the scanner from Sentinel to restore your frequencies.
To re-format an SD card, it's best to download and use this program:
