SDS100/SDS200: I got a problem
baloumax
Edmundston nb
Hi all i own a sds 100 my problem is i used to do a overnight discovery got a bunch of hits even if they were enxrypted etc
Now SINCE I FORGOT MY SCANBER IN MY LOADER IN -20 celcius. It finds nothing on trunked discovery and when i scan still nothing but i do pick up weather
What could be wrong
Coincidence my old uniden scanner seems quiet too
MAYBE TOWER PROBLEMS???
Is there a way to test my sds 100
baloumax
Edmundston nb
Forgot to mension
Unit seems to be working ok screen scrolls if i drop squelch below 2 it stops scrolling and static
richardbritt
State of NC
Northeastern NC
You might have issues with condensation leaving it out in the freezing temperature overnight. I would not keep it on, and give it a day inside to dry out. Unplug the battery as well. But I know I am over cautious with electronics, ever since I had a Motorola portable radio in my back pocket while I jumped from a Navy tugboat in the middle of Chesapeake Bay to another tug and the radio fell out of my pocket. Divers happened to be on the tug and retrieved it. 2 days later it was nothing but corrosion inside. And I had washed it with fresh water as soon as I was on shore in the radio shop. Water and electronics don't mix well
N9JIG
Sheriff
Moderator
Far NW Valley
The most common causes of "Nothing to Scan" issues is Service Types and Location. If you are using the Full Database be sure that the location is set properly. Then check that your Service Types are turned on.
Same goes for Favorites Lists.
kg4icg
Crazy Trucking Mechanic
Woodbridge, Va
Sometimes a location like punching in zipcode or auto locate will solve that problem of nothing to scan
