Wouldn't that be a 5Runner?Judging by your pictures-is this going into a 5th gen 4Runner?
Yes indeed!Judging by your pictures-is this going into a 5th gen 4Runner?
Yes but your wallet remains fatter compared to buying an equivalent Motorola.Yet again, the Harris gravitational well is sucking the $$$ out of my wallet
Thank you very much! I've learned bits and pieces of this information the hard way. I ended up with a -007 charger when what I needed was a -026. It's difficult to find just the sleeves to swap in in order to reuse the electronics. I have some NOS NiMh batteries that I'm conditioning right now but having a drop-in charger would make life easier. Even though the 100P wouldn't drop in without mods to the sleeve I can still put in just the battery.see below
I bought mine along with a 721 control head on ePayAnyone know where I can find the newer desk mic for the XG-100M?
Howdy I just purchased my first XG-100M and I am also interested in learning the info you are sharing about the process to unlock wideband. I could not figure out how to send a PM though.PM me for info.
You are not going to unlock wideband.Howdy I just purchased my first XG-100M and I am also interested in learning the info you are sharing about the process to unlock wideband. I could not figure out how to send a PM though.
Copy I have never been much of a forum guy so this is new territory. 👍Pretty sure newbies can’t send PMs until a certain number of posts…
-B
Thanks for the reply. My xg100M actually has wide and enabled (no option 50), however I have been keeping an eye out for a portable and was curious about possibly doing the same to a portable if I found a nice one for cheap.You are not going to unlock wideband.
Might be just my firmware version but programming Low Band, High Band, and UHF, I have wide or narrow. 700/800 is narrow band, no exception.
This is what is stuck in mine: XLP R06T02, DES version 2.06, AES version 5.01
That is an awful elucive manual. I have a full complement of desktop chargers and pockets, and been trying to build up all the charger documentation I can fin. So far, very incomplete.For vehicular charging of my NiMh batteries I have a VC4000 tri-chemistry charger (CH-017231-002). I've searched up and down the net for the factory manual which appears to be MM-018439-001.
I'm particularly interested in the DIP switches which can control the following
- Dual Charge Rate: Allows
charge rate to be adjusted
through dipswitch configuration.
- Dual Trickle Rate (only for
Nickel): Allows trickle rate to
be adjusted through dipswitch
configuration.
- Ignition Sense (Dipswitch
configurable): Unit is turned
off when the ignition is
turned off, preventing vehicle
battery drain, or unit is on at
all times.
...and not so much interesting but who knows
- Repeater Control: Has an
enable/disable circuit for use
with a vehicular repeater.
The vehicular repeater is
enabled when the radio is
removed from the charger.
You and a lot of other people. Since the narrow banding mandate, wide band able radios are very hard to find and expensive when you do find one.Thanks for the reply. My xg100M actually has wide and enabled (no option 50), however I have been keeping an eye out for a portable and was curious about possibly doing the same to a portable if I found a nice one for cheap.
