I joined the cult (New XG-100M owner)
BMDaug
I am licensed…
Central Colorado, USA
Yes it shows up when set to the CH-721 head. I knew it was there somewhere, thanks for pointing that out.
However it doesn't help with a CH-100 head. Some day maybe I'll have one.
Right. Changing the radio type show and hides certain options menus. You can’t do assign any of the radio keypad options on CH100. It’s either there in the menu structure or it’s not.
-B
Teotwaki
SoCal
After the “new” microphone I ordered was a dud I decided I’d rather have a desktop mike for the home radio. I found a package deal with a very nice ZN9F mike and a brand new Scan control head.
I don’t need the control head but I did get a new speaker cable with it. That’s a keeper!
mancow
N.E. Kansas
I haven't taken a control head apart. I wonder if the display window can be removed? Mine is roached. I would like to get a cheap system head and steal the display from it for mine.
Teotwaki
SoCal
I think the cheapest per unit price I’ve seen was 5 for $100 on EBay.
Teotwaki
SoCal
So back to essential Cult Knowledge: What format is used for audio files in RPM2 "Voice Annunciation"? Any tips about setting them up for the buttons of a CH721 System control head?
Thanks!
Teotwaki
SoCal
Thanks!
is it using VAC extension files for Virtual Audio Cable applications?
2154
The XL-200 mobile is a very nice unit and improves greatly on the XG-100/CH100 setup but still has some simple gripes. It is much more responsive (especially under the later firmwares), easy to read display, buttons are friendly to use with a load of functions to each one. The biggest gripe I have on it which doesn't seem to be of concern for TAC is you can press the selector down to display the functions of each button on the display, but when you power off/on the radio, it doesn't stick and you have to retoggle it every time. The mic is a USB-C connection and programming is via a USB-C or WiFi.
Teotwaki
SoCal
Been searching the Forum and found this
"Export to 8kHz 16bit .wav and then into RPM which converts them to .ilbc files before sending them to the radio."
  • 14221-7200-6110RevE.pdf
Teotwaki
SoCal
It took a bit of experimenting but I succeeded. First I created a mono 8kHz 16bit WAV file using Audacity. Next in RPM2 I created a new announcement VACONFIG001 file and imported the new WAV file. In RPM2 there's a limit on naming and file length.
Next I selected the Radio tab, selected Voice Annunciation and programmed the audio file to the radio. After that I went to the plan's Options drop down of Voice Annunciation and assigned the new sound to my "Talk-around On" button (B). Uploaded that to the radio and voila! It speaks!
jess_sherman
That's good information. Interesting that the mic is a USB-C. Sounds like there's no digging around under the seats or in the trunk to find wherever the installer put the unit when they come in for programming. That part I like!
BMDaug
I am licensed…
Ya, the XL-ESM on the XL200P is USB-C too and the Wi-Fi programming is rock solid and very fast! Just pull a few cruisers into the air conditioned bay, and program them all at once wirelessly!
-B
jess_sherman
The initial programming is what gets ya. I have the OTAP after that, but I did an upgrade some time back and haven't been able to use it since. I need to get that fixed, but I guess I'm just being lazy about it.
BMDaug
I am licensed…
Ya, for initial programming of a quantity, it’s easier to just make a temporary network that matches the default settings already loaded. Then you can Wi-Fi them, put in a plan with your own defaults and kill the temp network!
-B
jess_sherman
-B
Smart! Might have to try that on the next bulk purchase.
wa8pyr
Staff member
Lead Database Admin
Ohio
Compared to a 185/200, it feels solid, heavy, bulked up...and I'm sure that's because the housing plastic is MUCH thicker. That's most likely how it survives the torture test Harris claims in the flyer.
I'm still somewhat amused by the fact that the NFPA-specified survival conditions for these things would kill any firefighter long before the radio was affected.
