BCD325P2/BCD996P2: I need help with a Uniden BCD996P2 !!! Very frustrated.
dave3825
Suffolk County NY
Last chance and i'm out.
When in weather scan, do you see the display scrolling freqs in the 162 mhz range? If so, what is the squelch set at? And you do have the antenna hooked up and extended if its a telescoping type?
HeyPatrick
When I hold the WX button it is now showing a screen saying "WX scan" and FM ATT underneath. The word "SCAN" is floating across the screen in between, no numbers.
wtp
Port Charlotte FL
hey patrick,
if you enable personal messages, i can send some hints on how to manually program the radio.
or send your parents to this site and i can send it to them.
also ATT on the screen means that attenuation is on and that cuts the signal to about 1/100th of the original.
dave3825
Suffolk County NY
I bought a Uniden BCD996P2----but all I get is static or nothing.
One of a few important questions asked at noon.
9 hours later,
I got it working thanks. Antenna was loose.
Special thanks to those who helped, also to those who were very unfriendly.
Was I helpful or very unfriendly?
wtp
Port Charlotte FL
dave,
i think most that come here with a question only want the "you just have to hit one button" fix.
keep trying !
and thanks for trying.
DJBio
PEI
i would recommed a radioreference membership and you download proscan
with both of these you can pick what frequencies you would like
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Wow, what a thread. HeyPatrick has deleted his account. Sometimes storms blow through quickly on these forums.
