IC-A24 external headset microphone problem
elcad
Hi.
We have 2 radios IC-a24 with 2 headsets. When I connect headset there is no possibility to use microphone of this headset. Build-in microphone still active but you can hear by headset dynamics.
I`ve checked both adaptor cables for continuity - its ok. Checked resistance for dynamic - the same for both headsets. Resistance for microphones - the same on both. Suppose there is some setting on radio for using of headset. Is it?
Guys said that before it was ok : when you plug it works.
I`m not professional in radios.
So please advise some solution.
Thanks in advance
