IC-F121 w/OPC617 for APRS or TNC
AK9R
Super Moderator
Central Indiana
The OPC-617 is not a serial adapter. It's an option cable that gives you external access to some of the pins inside the radio.
I have an Icom IC-F1020 that I have used for packet and APRS while connected to an external TNC. The F1020 uses the same OPC-617 cable that the F121 uses.
Attached is the pin-out of the OPC-617 from the IC-F1020 manual. Just match the pins in the OPC-617 to the radio port pins on your TNC.
DODGEIT
Sarasota Florida
I have a didgipeater set up with a Icom f-121S. I had to get a cable that used the mic jack and the speaker jack. I got one from Associated Radio Communications CAB K101 Now that is for a Kantroniics KPC-3. It is in service here at a local hospital.
