Icom F62D Won't send Tx ID
I just recently got a Icom F62D and cannot get it to send an ID when transmitting. I've programmed for hours and can't figure it out. It is being used on NXDN conventional to communicate with Kenwood units. Voice communications work well but the Icom will not send an ID or an Over The Air Alias. The catch is that if I transmit on the Kenwood first, then the icom will transmit the correct ID with the Over The Air Alias in return. It's almost like there's a reset timer somewhere that turns the PTT ID off after communicating with the Kenwood unit. Not using any talkgroups or anything like that either. I'm not an expert on Icom programming so I'm sure I'm probably missing something. Any help would be greatly appreciated! Thanks all.
Updating for anyone else with the same issue. Three more hours of tinkering and I figured it out. You must assign the Icom's group ID to 0 if you want the Alias to work correctly with the Kenwoods.
