Icom: ICOM IC720A
caerickson
Phoenix, Arizona
Has anyone had a problem with receive audio on an ICOM 720A on upper sideband only? The radio receives without a problem on lower sideband and AM, but is distorted on upper sideband. The operating frequency is zeroed using WWV.
Any guidance on how to correct this problem will be appreciated.
Chuck Erickson
K7CAE
caerickson
Phoenix, Arizona
ICOM 720A
I was finally able to find a parts only IC 720A and switched out the IF Board to my IC 720A. The radio immediately started working properly.
If you have a similar problem with the Upper Side Band on an IC 720A, start with the IF Board which is most likely where you will find the problem.
