CSFD390
Hi all, in need of assistance. I have 6 ICOM IC-F3021S portable radios, that are in need of programming.
Before anyone throws at me for not being a "licensed ICOM tech., I understand, and do not need that as answer, or "take it to a certified dealer". That's not why im here.
I have acquired the software, and cable from a member in our station, all software and cables, (OPC-478UC) ARE LEGAL, AND WERE PURCHASED DIRECTLY FROM ICOM. These radios are being used for the sole purpose of supplying exterior members, and first responders with a way to communicate until we order new radios. I have installed the cable driver CD, and the actual software as well to my Windows XP Desktop. I have registered a proper ID code, etc. I am currently been at this software, for about 2 hours trying everything i can think of. I have my radio, plugged into the proper speaker jack, located on the side, in the proper hole, and the USB plugged into my computer. I believe im in COM 3, due to when I try all other COM Ports, they state, "Cannot detect COM PORT 2" for example. SO, im properly hooked up, and i select COM PORT 3, it takes a few seconds, and i get another error message, that states, "No answer from transceiver".
These radios have not been reprogrammed, or touched in any form as far as programming, and I have the current software in which they were programmed with.
I've tried 3 different radios, all stating the same thing.
"No answer from transceiver", please check the COM PORT SETTINGS, CLONING CABLE CONNECTIONS, TRANSCEIVER IS ON.
Im at a loss as to what to do. I have plenty of experience with programming Motorola radios.....but this has me stumped.
ANY help is appreciated.
Regards, Michael.
Regards, Michael.
