In the SDS 100 ID search mode, when an ID is found and transmitting, the ID number shows but as Unknown. Is there any way to insert text in that field to identify who the ID tag is associated with?
Regards,
JLD
Regards,
JLD
Of course, program the talkgroup into your favorites list with a text tag.
How do you hook up SDS100 to PC to run Proscan?Id search will see any tg not programmed into a fav list. Either take note of the system scanning at the time or I believe there is a way to append it to the systems it’s scanning. From that point you can read the scanner into sentinel and assign each unknown a text tag and then write back to the scanner. You can also id the unknowns and make a submission to radio reference database.
yesDo you have the same multi-county (or statewide) system broken up into 7 favorites lists?
thanks, I'll try that.Same was as connecting to sentinel. Plug cable in, select Y for mass storage mode. Open proscan and click on Find Scanner under comm ports section.
