jakes_tornado
Or will I have to have the radio programmed? Because I Could just scan the 800 mHz band right? I am just wondering because it has a simple concept.
That is totally true. But, is it possible?
I totally understand. I was just wondering because it seemed like a simple concept to me.
Just out of curiosity, what makes the XG-100 a poor scanner?
Just getting back to this thread.....I don't check in often.
One reason a scanner is better than a radio has already been mentioned. It does not allow you to transmit on channels/frequencies that you are not authorized to do so.
Another big thing for me is the Close Call function of many scanners. You do not need to know what is in use in your area, let the radio find it for you. A Harris Unity radio will never do that for you.
Also, my Unity radio is for inter-operability between local and Federal users. I have time to program and load new "Mission Plans" as needed. A scanner you can easily program from the front panel, or PC if needed. The Unity radio is PC first and limited front panel capability.
Then, for transmitting and scanning, you tend to miss certain critical transmissions while scanning. So using a scanner for listening is still the best method, and much cheaper, with less hassle.
I don't have the programming software because I have a mac. 2,
How old is your Mac? You don't have Win7 installed and set up to dual boot?
You can also load Windows via Parallels, VMWare Fusion or VirtualBox which is free. That way you don't even have to reboot your Mac. Virtual machines are great.
