- Joined
- Jun 9, 2013
- Messages
- 74
more rebanding?
Hi - do you know if rebanding is happening again for Caldwell & Burke Counties ? Thanks
QUOTE=trumpetman;1979152]I'm seeing several of the same posts recently one after the other, and receiving several PMs & emails all about the same problem: "Where did VIPER go?".
VIPER is going through the rebanding process right now. The short of it is, due to Nextel interference in the adjacent band, all public safety systems in the 866-868 spectrum are being reallocated 15 MHz lower.
Service teams are moving very quickly over the western half of the state and hopefully in the coming weeks, all 100 sites will be completed.
If you can no longer receive a control channel for the VIPER site you are monitoring, subtract 15 MHz from the original frequency and that should be the new control channel frequency (and the rest of the frequencies in use at a site). Example: If the control channel was 868.6875 then it now becomes 853.6875. Simple as that. Same holds true for the alternate control channel and all voice channels. Occasionally there will be some interference and frequencies will have to be altered. If that is the case, search from 851 MHz up to 854 MHz and you should be able to find the new control channel. Once this is located, report it to the database via the SUBMIT button and we can update it for the rest of the users to see. A Trunk88 report would be a tremendous help from anyone that can run it. Make sure you add in the new custom plan there AND apply the custom plan as well. Just shoot it in an email to me. As usual, it's my username (at) radioreference (dot) com.
Now that you have found the new frequency for the control channel, you must also enter in a rebanded/custom band plan.
All you have to do is plug in 2 lines that are as follows:
Lo Freq | Hi Freq | Step | Offset
851.0250 | 854.0000 | 25.0 | 440
851.0125 | 868.9875 | 25.0 | 0
Nothing more, nothing less.
Make sure, especially with RadioShack/GRE scanners, you tell the scanner to use a custom bandplan once you set it. With Unidens, I believe it assumes to using a custom plan once it's entered.
If there are any questions, ask away, but please try these instructions first before panicking and plastering the forums with the same questions over and over.
For anyone that PM'd me or emailed me over the past few days, these instructions will help; I would normally respond to all of you, but I've been super busy lately and it would've taken forever to answer all of you. Let's keep it to the forums so everyone can learn from this new experience this time. If you've tried all of these steps and exhausted any testing/troubleshooting, THEN post here to see if we can determine what you're doing wrong.
TL;DR: Rebanding, patience, & custom bandplan.
Also to make it easier to help you out please state which model scanner you are using and which software package you are using to program it. [/QUOTE]
