Ignition Relay
adko701
Whitehall Wisconsin
I need a relay for my radio equipment. This is how it has to work...I turn on my key, all my equipment comes on. I have one spot on my fuse box for the relay trigger. I have 3 items I need to turn on...A Motorola CDM1250, Uniden BCT15, and a GPS. Any ideas?
ffemt601
MS
Its called a Relay and you can buy them at an auto parts store for around 5 bucks. You buy them based on the amp rating needed for your gear.
Personally I use EVModules - Products so that I have a delay that my gear stays on after I turn off my vehicle.
WD4JKH
Peach State
If you run the main power lead from the CDM through the relay you will be having to punch your power button on the radio every time you turn the ignition on. The way a CDM is normally done is connect the CDM's power lead to battery hot and use the ignition sense in pin #10 of the accessory connector. Another way is to run the power lead AND the ignition sense through the relay. That works also if you want to make sure you have zero drain through the battery when the ignition is off or if everything is run through a battery disconnect switch.
WD4JKH
Peach State
CDM's have to have pin 10 ignition sense enabled in the CPS
It seems like all the new ones I have seen lately have ignition sense enabled as the default setting.
The handy part about using it this way is you can still power on the radio with its on-off switch with the ignition switch off.
RolnCode3
Sacramento/Bay Area, CA
Sean is a genius. This was the exact item I thought of when I saw the thread. Hook that to a BlueSea fuse block and you're golden.
adko701
Whitehall Wisconsin
Well, radio install almost a success. I purchased 2 relays..this one to be exact (http://www.justanswer.com/uploads/st...4305_relay.gif)..and it works perfectly. I also ordered a ignition sense kit for my Motorola CDM1250, although I hooked the positive lead from the radio to the positive side on my relay and it works perfect, also the ground to ground. Is this way wrong? Is it alright to hook two relays up to one ignition source at 10AMPS? Can I hook the wires together to turn the relays on at the same time?
Thanks!
Happy Holidays
FFPM571
The Mid South
10 amps is alot. All a relay needs to work is about 100ma to tell it to work. Yes you can run 2 relays off the same igntion source
