BC296D: I'm looking for BC296 programming cable.
epka_pol
Kielve, Poland
Hi guy.
I'm looking for BC250D/BC296D programming cable.
I bought 3 different cable, but they fit all other Uniden scanner accept BC250D/BC296D.
This popular cable fit BCT15 BCT15X BC346XT BC346XTC BCD996T BCD996XT BC95XLT,
but it's NOT compatible with Uniden BC250D/BC296D Scanner :(
Programming Cable for Uniden BC250D BC296D
This cable does not fit Uniden BC250D/BC296D Scanner
tvengr
Well Known Member
Baltimore County, MD
You need to be careful which cable you buy. Cables listed on Amazon which claim to be for the BC296D do not fit. They also list later scanners which use the Uniden USB-1 cable. The later Uniden scanners use a Hirose connector which does not fit the BC296D. I have a BC296D cable left over from a scanner I programmed for our news department many years ago and the connector is definitely different from the Uniden USB-1 Hirose connector. You probably will have a better chance purchasing the cable from a private party who knows it fits. I am going to hold onto my cable since it is so rare. The original cable has a female DB9 connector for connection to your computer. There may be other cables with a built-in USB to serial adapter which will fit. If you find a cable with the DB9 connector, you will need a USB to serial adapter between your computer and cable unless you have an old computer with a serial output. Here is the USB to serial adapter I use: https://www.bestbuy.com/site/insign...Vp0hHAR3hljROEAQYASABEgJKe_D_BwE&gclsrc=aw.ds
fxdscon
¯\_(ツ)_/¯
The Uniden BC250D/BC296D programming cable has been impossible to find for years now, except for very rare listings on Ebay etc.
There was a listing on Ebay a few years ago that listed a BC296D scanner for sale including the cable, but I haven't seen anything else since then. As far as I know, the BC250D and the BC296D were the only scanners that used that cable, and those scanners are over 20 years old now.
As @tvengr mentioned above, most all ads online for that cable incorrectly state that it's the same cable that all the other listed scanners use.
The photos below show the scanner end of the correct cable for the Uniden BC296D:
296-jpg.119354
296a-jpg.119357
The BC296D connector plug shown above is longer than the Hirose connector used on the other listed scanners.
Also, it's rectangular shaped with 90° corners rather than "D" shaped, and does not have any keyway in the plug like the Hirose connector does.
Ronaldski
MI DB Admin
Bay City MI
epka_pol
Kielve, Poland
I don't need DB9 (serial) to USB, I have 5 of those, CH340, profilic and FTDI chip ;)
I need the one that is connecting to the scanner :)
Ronaldski
MI DB Admin
Bay City MI
I have programmed I think two of those vintage scanners using the adapter cable.
They should work, since what your doing is plugging the usb end of the adapter into the pc, leaving the serial connector on the other end.
Plug in your *original cable's serial port end into the adapter cable serial end and other end of the original cable to the radio.
Just a matter of getting the cable driver to make the adapter cable work.
I will say the one I listed above that I have is my third one over 10 years or so. Either the other cables went bad or more likely windows updates made them not work as they made any counterfeit ftdi not work years ago. Have had that current one since 2019.
Also should work, https://www.amazon.pl/DIGITUS-Adapter-port-szeregowy-Typ/dp/B00CI63N6C/ref=sr_1_12?__mk_pl_PL=ÅMÅŽÕÑ&crid=1GOKF91330PWY&dib=eyJ2IjoiMSJ9.OLCM-wqNV5xyhVHtmasLe7Ek3o-5uEXrpxSm5lqlokmxpr48t0pqh6T8ncjfPHwh8tf_dW2HgLtSKdSTJT6hKNywsXIa2uivnpcrRpDxuPG4DZJ052lUvvy8kCy8uc8muMqhesKlMSDfB2wCdrEaQ2pWoSjuEwOhlIWwo5KeYimrg3Ea7BPB44xJrNZGW4Z494hfecL_YpKSOw3dn0yiuXEldwYMMpfuaz9cbz9iZBHwXHH51CRTEdNwOrskG69BTp8n18LdV6C5JOC_Zs38pDoBjqHQ9S-l1twENwTwbKA.iydBxRZmP-k2F4otS4dKJ5dkabqYiTTNdMaMAxyf4W4&dib_tag=se&keywords=usb+serial+port&qid=1732378912&sprefix=usb+serial+port,aps,167&sr=8-12&th=1
epka_pol
Kielve, Poland
I don't need DB9 (serial) to USB cable.
I need Uniden *original cable*
Ronaldski
MI DB Admin
Bay City MI
He doesn't have an original cable.... that's what he is trying to find.
I'm not seeing where he stated specifically before reply in #7 not having the original cable, based on how the replies are worded suggest he may not, but it's not certain exactly.
So assuming you dont have the original cable, just keep looking and of course will be awhile, but in the mean time I would program the scanner(s) manually, assuming they can be. Tedious, but would work.
If someone knows or can be found is the name of that connector on the radio as that could be an assist for a cable search.... potentially.
tvengr
Well Known Member
The BC296D can be programmed manually. I didn't have software when I programmed one for a large trunked system. I wore out the scroll control selecting characters for alpha tags.
garys
Central Texas
I think everybody else understood what he was looking for .
garys
Central Texas
When I bought my 780, there was no software available. I spent eight hours over three days programming it by hand. I think that's where my Carpel Tunnel problems originated. ;)
garys
Central Texas
I had a similar cable for an old Cannon camera and while it physically fit, it wouldn't work. I Anull modem might have been required, but I never got that far.
Should be the same cable as some of the old Fuji cameras
Or
cmjonesinc
I suppose the db9 one could be easily repinned if all 4 wires are present.
tvengr
Well Known Member
A null modem adapter in not required for the BC296D cable with a DB9 connector. Only needs a USB to serial adapter.
cmjonesinc
Not for an original cable. Garys was commenting on the non oem cables I posted with the same type connector which could have a different pinout.
garys
Central Texas
I was thinking if a non original cable was attempted. Since the originals no longer seem to be in existence that might be the only viable option.
