What would be the best indoor antenna that works well for all bands. No attic space and could not put on the roof. Something better then the stock antenna. Any suggestions.
I do have a metal book end under it. Works pretty nice. thanks for all the advice.
how thick does the ground plane need to be? Does thickness matter or just surface area?
I'm with Brillian on the Radio Shack (Model: 20-176) antenna.What would be the best indoor antenna that works well for all bands. No attic space and could not put on the roof. Something better then the stock antenna. Any suggestions.
If I use the Radio Shack (Model: 20-176) in my attic would it improve the signal if i mounted to a cookie sheet ground plane?
I have my magnet mount antenna on a cookie sheet. Does it matter if the antenna is not in the center of the cookie sheet more towards the back
It is a rectangle that is 14x10in. Where would the best location be on the sheet. I now placed it in the middle.
