Inside house install
tommyscan
seaford new york
I need some suggestions from those antenna/install pros!! I cant put an antenna on the roof due to expenses and neighbor problems. Can anyone give me advice on how to install a portable antenna in the house to boost my signal?? I have the mag mount spectra, and several frequency-specific antennas. Any help would be appreciated.
KC0QNB
Gothenburg, NE
Got an attic?
tommyscan
seaford new york
Negative on the attic. I have tried mag mounts on the radiator grill but no difference. i guess I am stuck with what I have. I was hoping to clip something outside the window for improvement but no such luck.
KD4KNR
can you get on the roof??
Attach a ventenna to one of your vent pipes (spray paint it match the color of the vent pipe) nobody would ever know!!!
KC0QNB
Gothenburg, NE
you can get a base adapter for nmo type antennas, of course there are different models, make a bracket that attaches to the window sill.
mlevin312
Will mounting in the attic really work
I was considering putting an antenna in my attic (probably the radio shack mag mount that I already own) will this really improve reception and if so how should it be mounted?
Don_Burke
Southeastern Virginia
If there is something up there that is big and ferrous, it could work out very well. Steel ductwork or an HVAC air handler have all kinds of possibilities.
I have used the front panel from a washing machine, others have used an electric football game as a ground plane.
