Installing A FireStik: Best Placement on F150
jonwienke
More Info Coming Soon!
VA
Blenderite
Then the problem has nothing to do with the antenna. It is either a radio problem, or something in the vehicle is generating RFI on the power leads even when the ignition is off. Try putting a filter on the power leads like this one:
https://www.amazon.com/Magnum-XLF-20BP-Common-Power-Filter/
If that doesn't fix the problem, you need to get your radio fixed.
I will check it out, thanks!
Sent from my ONEPLUS A3000 using Tapatalk
jonwienke
VA
The filter I linked uses multiple turns of wire around a ferrite core, along with capacitors for additional filtering. It will work better than just snapping ferrite beads on the power wires.
Blenderite
That is what I figured. Thanks!
Blenderite
I just did a quick test where I removed the trucks power cable to the battery and then held the power cable from the radio to the positive on the battery, so the radio was the only thing connected to power. and unfortunately, I still got the static, no better (or worse) than before.
Is that a good test of whether it is interference from the truck? It must be, nothing else was getting power so how could it be interfering? So assuming that interference isn't the issue, what could be wrong with the radio itself? Can it be repaired? If so, who does that sort of thing? There are no CB shops around me.
Thanks!
jonwienke
VA
It can't be the truck if nothing is powered. RF interference requires an energy source to generate the RF.
Either your radio is broken, or you have a bug or tracking device powered by a second, hidden battery in your truck somewhere. Does Ford have something similar to OnStar?
Take the radio out and power it up out in the boonies far away from your truck or any power lines, vehicles, or electrical machinery. If it still has the noise with the antenna disconnected, get a new radio. If not, you need to look through your truck for "extra" wiring or devices.
Blenderite
It would probably be easier to get a different radio than to take this one out to the boonies. I might get one off Amazon and then return it if there is no difference.
So I am assuming that there is no way to repair the radios if there is a problem, or is it that they are too difficult to diagnose for untrained people?
jonwienke
VA
The latter.
It's unlikely you have access to the test equipment or technical data you would need to fix it yourself. You may want to look into warranty repair if the radio is still covered.
I'd definitely try a different radio, then go from there. Can you borrow one from a friend temporarily?
Project25_MASTR
Millennial Graying OBT Guy
Texas
What's your radio? Make sure your RF gain is turned all the way down and the noise blanket is on. Open the squelch up and adjust the gain to where it just begins to raise the signal strengh bar. Then adjust the squelch to eliminate the noise. Check and see if the squelch is at a lower point now.
Blenderite
I have the Uniden Pro520XL. I will double check my settings on the RF and squelch, but I know I played around with them the other day and was able to eliminate the static, but I never heard anything. If I turned everything back down, I could hear people talking, but the static made it difficult to understand them. Perhaps I should have shared this tidbit sooner.
Another idea, which I am sure is really stupid, but I want to eliminate any possibilities. I have my antenna on a Firestik heavy duty steel spring. Are those directional? The stud came out of it and I didn't pay any attention to which end it came out of when I went to put it back on. It doesn't appear to have any direction to it, but I figured I would ask.
Blenderite
The latter.
I sent Uniden an email last night describing the situation. We shall see what they say.
jonwienke
VA
No. At least not electrically. If one end of the spring is fatter or heavier-duty looking than the other, that end should attach to the mount. But if there isn't any difference mechanically, then it doesn't matter which way the spring is mounted.
Project25_MASTR
Texas
So depending on how far away from you others are, you may not hear them clearly.
Blenderite
While I wait for my noise filter, which should be here by 8pm tomorrow, here is a sample of the static without it.
https://youtu.be/n0aHEwN7oGw
Does that sound normal or excessive? How much do you think the noise filter will help?
Blenderite
I got the noise filter and all installed. It appears to be a lot better than before. I might try moving my coax farther from the wire run, but it is not bad enough for me to rip up the carpet again! Thanks for all your help!
