installing freescan
i900d
gents i have just installed freescan on my computer. i have a uniden bcd 396t so i installed the usb driver for windows xp and for some reason when i plug the usb cable in it sends my computer into a shut down and memory dump state. any suggestions
teufler
ST PETERS, MISSOURI
First uninstall Freescan, then plug thecable in. Doing this you can determine if its Freescan or the cable. Then I would try a copy of Proscan . The trial copy is full wortking for 30 days. See if you difficulties occur again.
i900d
freescan
i have now installed freescan on a different computer but now it will not connect to radio reference any thoughts
teufler
ST PETERS, MISSOURI
You now have Freescan loaded. Did it select a comm port correctly? Control scanner, comm port setup. You might go into control panel on the pc, system, device manager, comm port setup and see if a comm port is selected bty the compurter though if Freescan selected as says ready to go, this would be meaningless.
i900d
Freescan glitches
Thanks for your help. Still having issues. Will have to back track
