SDRTrunk Integrating w/ Rdio-scanner - Linux
maus92
Eastern Shore
I'm trying to find a solution for organizing recordings produced by SDRTrunk on the Linux platform. I decided to try Rdio-scanner, and I have it working with one system using the API method (not Dirwatch). I have two other systems that I monitor and want to add them to Rdio, however I am unclear about setting the API key for additional systems: do I reuse the API key that I created for the first system; or do I create unique API keys for each system that I want to monitor?
maus92
Eastern Shore
Nevermind - AI answered the question. It is not necessary to create unique API keys for individual systems. I tested it overnight, and traffic was ingested from two systems using the same API key.
timkilbride
Linn Co Iowa
I would use separate API keys for each system. If you need to disconnect one but not the other, you can with separate keys.
Tim
