I have a Bearcat III H/U which uses 10.8 IF crystals.
I have a crystal marked "460.425MHz MRU-1" which I interpret as being a 10.7 IF crystal used to receive on a frequency of 460.425MHz.
Can I put this crystal into the Bearcat III and if I can what frequency should I receive in the Bearcat?
My initial assumption was that if I subtract 10.7 from the frequency, then divide by 9 I would get the crystal's real frequency. And then armed with this value I could find out what its UHF frequency in the Bearcat would be (460.525MHz).
Does that sound right? Or does the fact that it's a 10.7 IF crystal change something in this equation that I'm missing?
And to answer the first half of my first question I tried putting the crystal into the Bearcat and, by some arcane magick, is currently picking up traffic off a local repeater. However the repeater (as far as I'm aware) is a high band frequency and not UHF, so I shouldn't be picking it up in the first place.
And I have check at least a dozen times that the crystal is plugged into the UHF module and not the high band module.
