I'll comment, but i wouldn't consider it a review, even a mini-review, since I just haven't used it enough yet.
As you would expect, the item is very small. It appears to be very well put together. Some things you will need:
1. You need an SMA-Male connector to screw into the SMA-female on the dongle.
This is a dinky connector. Obviously it is chosen for its size [it'll fit within the package] and because anyone who is using this dongle will probably be using a light but high-quality jumper to attach this dongle to their particular feedline.
So, depending upon the feedline/jumper you are planning on connecting to the dongle, you are going to need something that ultimately terminates in an SMA Male connector.
2. In Windows, at least, most of the SDR applications that you can use with the the FCD require you to also run the standalone FCHid program (which allows you to set the frequency). One exception is WRPlus. There is a DLL avvailable on the FCD website that allows you to use the facilities within WRPLus to set the frequency. This is extremely useful. BUT, it will not work unless you have installed Firmware 18f.
You'll want to join the
FCDevelopment Yahoo! Group. The DLL to use with WRPlus to allow you to adjust frequency within WRPLus is available in the Files section of this group. It is called
ExtIO_FCD.dll.
Spectravue can be obtained on the
Moetronix website.
WRPLus is available at
WRPLUS
Instructions for setting up the device and configuring it for use with Spectravue and WRPlus can be found on the
FunCubeDongle website.
I haven't gotten as far as feeding the output of this into another application via the internal audio subsystem, but it is possible. For instance, it would be possible to tune to a frequency with this device, using WRPlus, and then feed the output from the dongle into another application (such as a Unitrunker or Trunker, HamRadioDeluxe, etc) using some internal magic. I haven't done it, but other people have.
You do want to make sure you follow the procedure for reducing the DC offset and reducing images [image rejection].
This device is very sensitive, on 2m, VHF, UHF and 800 Mhz it appears to be on par or better, sensitivitywise, with my PRO-197. Of course, if you have strong transmitters closeby near the frequencies you want to operate, you are going to want to get some filtering in place. This will overload as easy or easier than my PRO-197 will.
You can adjust gain at various stages, which is very interesting.
Anyway, so much for a review. This is just some things to get you started.
Incidentally, you get about 80 khz +- the center frequency that you set the device to. For instance, if I set it to 155.220, the range on the waterfall where I can see signals is from about 155.180 to 155.300. The device specs at 96 khz, but there are reasons why you only get 80 khz. I just don't know enough about it to tell you why it is 80 khz.
The author is working on the API functions to allow third party software appliccations to interface with the device and control it. This aspect is still in its infancy I think, so I believe the only Windows program you will find that will allow you to tune the FCD directly is WRPlus (with applicable DLL installed per instructions and Firmware 18f or newer]. Over time I'm sure more SDR applications will be able to hook directly to the API Howard is creating to allow that particular application to control it directly. Until then, for some applications like Spectravue you have to run Spectravue itself and then the FCHid progam to actually tune the FCD.
Oh, one last thing - if you follow the directions on the FCD website, it is very easy to upgrade the firmware on the dongle.
Purchasing one is at least half your battle. I got one on the first try. I started exactly one minute early. I have a Paypal account. I opened one browser window and logged into Paypal beforehand. Then I opened another window and went to the FCD order page. At 1 minute before 5 PM I started ordering. The first two times it said it coudl not be ordered. The third time (in about a 30 second timeframe) I was able to buy one.
Make sure your computer clock is set to the right time. Start trying to order early. And repeat as fast as you can until you get an order in. Do that for at least 5-6 minutes. If you still can't order one within 5 minutes after the start time, it'll likely be because they are truly sold out.
Mike
