After several minutes of rigorous testing and development, I am proud to announce that I have completed an internal waffle maker mod for the BCD436HP scanner! Now you can enjoy the convenience of a fully functional handheld waffle maker without the hassle of external cables and extra power plugs.
The installation requires the internal GPS and hydrogen fuel cell conversion mods as prerequisites. The GPS patch antenna is modified to perform double duty as the GPS antenna and the waffle maker hot plate. An additional cutout in the case behind the USB and GPS jacks is required for waffle egress and the installation of a NEMA L21-30 480V 3Φ connector (required for faster recharging), and the factory GPS port is removed to allow the waffle mix to be inserted into the waffle maker mechanism. An additional bi-color front panel status LED is added, that glows green while the waffles are cooking, and blinks red when the waffles are done.
Impact on battery life is expected to be minimal. Run time can be as much as 13 minutes while making waffles, if the actual scanner is turned off.
A similar mod is in development for the 536 and other mobile scanners, but it requires an external waffle maker mechanism, because the adamantium case material is too difficult to cut holes into to mount the waffle maker mechanism internally.
Pricing is TBD, but are expected to be the lesser of 2 extremities of your choice, or the black market value of your first-born child.
