Intra-WACN roaming?
N
N_Jay
Guest
OK found one thats not BEEOO tht is the City of Oakland, CA P-25 that they are implementing.. It has the WACN of 92556 , but this is about the only differrring one I have found yet that is non fed.
Interesting.
At first I thought they used there Zip Code, but that is not it.
Wonder how they picked it?
INDY72
Indianapolis, IN
LOL no clue but only two in the entire DB I have found that have WACN's different than BEEOO are that and one in CT. There are a few no one has run Pro96Com or the like on yet that I would love to look at. But those two are the only ones thus far I have found in the US.. I could look at Canada too and see, they have an Harris P-25 comming together there as I understand it.
INDY72
Indianapolis, IN
On the Canadian Harris P-25 for Saskat.. Its WACN is I believe OOOOA..???
Another interesting fact about the Federal 380 MHz P-25 systems.. We found this by accident.. Each frequency also has an NAC for conventional usage allowing the radios to use each repeater in trunked or talkaround. This may be true also for the Non Fed P-25 systems but I don't have the ability to do NAC's yet to confirm this. I don't like to assume as it leads to bad conclusions, but it would be an beneficial aspect if so.
Here in Omaha the NAC is 140 for the repeaters.
RWC in AZ WAC is BEE08.
Dothan AL BEE09
Lakewood, CO 924B3
ARMER in MN BEE07
So there are some non-fed systems that have changeed the WAC.
Is BEE00 Motorola's default?
WayneH
Forums Veteran
Super Moderator
Your master site
FWIW, the infrastructure is not Motorola. I believe it's Harris. There was a news report about Oakland (City) selecting them (M/ACom actually) some time ago.
INDY72
Indianapolis, IN
OK so Motorola default for ASTRO-25 is BEEOO. And Harris P-25 is an mixed bag, with a few Motorola's having other. The magority still have same WACN, and for those that do not, there is ISSI . Using both you have very nice set up for interop accross the board on P-25 TRS's. Which is the whole idea to begin with. :)
