Introducing the SDS200
wmlovell
Aurora, OH
When streaming using the LAN to stream all of the audio & display go through the LAN? I could then send tags, too? ...and I would still hear my scanner through the scanner speaker instead of through my computer speakers? ...and adjusting the volume on my scanner wouldn't affect the volume on the stream? ...am I understanding this right?
TxScanner
Yes you can to listen
Using the stuff listed above, or can you give me a link to what i need, something i guess that plugs in the Ethernet port, and i guess has a WiFi box on the other end, not sure.
Sent from my iPad Pro using Tapatalk Pro
noaim
Milwaukee, WI
Don't need a program, need the Uniden instructions.
Thank you thou.
John
Uniden doesn’t make software to do this.. besides for siren on mobile devices which I don’t think it even works on the 200 you are asking for something that doesn’t exist at least as of now
Sent from my iPad using Tapatalk Pro
WD6ABC
Santa Ana, Ca.
I write software. One of the features of the 200 is streaming audio and control via the LAN port. The radio must have some commands to tell it to do those functions!
WD6ABC
Santa Ana, Ca.
The remote command specification link was posted in post #666
Thanks, but those instructions wouldn't include the LAN port. 200 has one where the x36hp models don't. Need to set IP address, etc.
Thanks Again thou...
John
mancow
N.E. Kansas
It's all basically the same as the 536 wifi just ethernet instead.
The radio has a lan menu. Set it to dhcp or specify an ip address. Go to proscan control port setup select ip enter ip or use the ip search. Go to audio tab select ip so same thing. Done.
WD6ABC
Santa Ana, Ca.
You were given the info by UPMan a few weeks ago when you asked the same question. Protocol commands are the same regardless of the media using.
Hmmm. I looked back and didn't see any replies. Sorry if I missed it.
(Did you catch the message # ?)
John
Houdini7
Now if we could only get the ProScan team to write a native Mac program... :)
buddrousa
I think Bob addressed that years ago for the x36's I think he said he is a one man operation and it would take up too much of his time to start from scratch with a new OS.
