This subject came up on the BCD396T Yahoo Group. "When are the scanner manufacturers going to support inverted DPLs?" Well, the truth is they have since they started supporting DPLs at all.
EVERY inverted DPL code is the same as a standard (non-inverted) code.
Here is a 'chart' you can look up your own. BTW, the codes
are mutually exclusive. If you look up one on the left as a standard
code, the one on the right is the equivallent inverted code. If you have
an inverted code, look that up on the left and the one on the right will
be the standard code. These are the standard 104 codes. If you have one
not on the list, email me.
Now you can program all those 'inverted' code users in your scanner!
023 047
025 244
026 464
031 627
032 051
036 172
043 445
047 023
051 032
053 452
054 413
065 271
071 306
072 245
073 506
074 174
114 712
115 152
116 754
122 225
125 365
131 364
132 546
134 223
143 412
145 274
152 115
155 731
156 265
162 503
165 251
172 036
174 074
205 263
212 356
223 134
225 122
226 411
243 351
244 025
245 072
246 523
251 165
252 462
255 446
261 732
263 205
265 156
266 454
271 065
274 145
306 071
311 664
315 423
325 526
331 465
332 455
343 532
346 612
351 243
356 212
364 131
365 125
371 734
411 226
412 143
413 054
423 315
431 723
432 516
445 043
446 255
452 053
454 266
455 332
462 252
464 026
465 331
466 662
503 162
506 073
516 432
523 246
526 325
532 343
546 132
565 703
606 631
612 346
624 632
627 031
631 606
632 624
654 743
662 466
664 311
703 565
712 114
723 431
731 155
732 261
734 371
743 654
754 116
Joe M.
023 047
025 244
026 464
031 627
032 051
036 172
043 445
047 023
051 032
053 452
054 413
065 271
071 306
072 245
073 506
074 174
114 712
115 152
116 754
122 225
125 365
131 364
132 546
134 223
143 412
145 274
152 115
155 731
156 265
162 503
165 251
172 036
174 074
205 263
212 356
223 134
225 122
226 411
243 351
244 025
245 072
246 523
251 165
252 462
255 446
261 732
263 205
265 156
266 454
271 065
274 145
306 071
311 664
315 423
325 526
331 465
332 455
343 532
346 612
351 243
356 212
364 131
365 125
371 734
411 226
412 143
413 054
423 315
431 723
432 516
445 043
446 255
452 053
454 266
455 332
462 252
464 026
465 331
466 662
503 162
506 073
516 432
523 246
526 325
532 343
546 132
565 703
606 631
612 346
624 632
627 031
631 606
632 624
654 743
662 466
664 311
703 565
712 114
723 431
731 155
732 261
734 371
743 654
754 116
Joe M.
