IP programming of SLR Repeaters
Jentry
Dubai UAE
Hi,
i am trying to read and write the SLR repeater trough RM via LAN. i did the following if someone could please correct me or guide me through properly on how to do it.
- i have read 1st the repeater via USB cable so that its in RM already.
- set the repeater as master on link establishment.
- check the box for IP repeater programming.
- Add IP system settings in RM
- attached the IP system on the repeater that i want to program.
- schedule job read or write and check IP program.
on RM Device Monitor the repeater is being seen and said its been downloaded but fail after a few minuets and will give error code 307. i have attached here a picture.
any help would be appreciated
Firebuff880
Boynton Beach, FL
Your Two Screenshots tell you the story --
Device Programmer can not talk to the Repeater Serial number you are trying to program.
You must use CPS and set the basic configuration in all the Repeaters first including;
Enabling the IP programming option.
Enabling the Type and pointing the appropriate settings to the Master Repeater
Ensuring the IP address / Port is in the same subnet / vlan assignment and Device Programmer is not blocked by any Firewall or Switch ACL rules.
Jentry
Dubai UAE
Yes i have done all of that. Also i am only using LAN to make It simple and less troubleshooting
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Is your IP system pointing to your master repeater? Are you trying to program a repeater other than the master (like a peer)? Is IP programming enabled on the RM device programmer? Can you ping the master and repeater you want to read from the RM (or device programmer machine)? TT
Jentry
Dubai UAE
Yes to all your questions :)
Jentry
Dubai UAE
Hi Guys! thanks for replying. i have found what is the cause after using Wireshark. i found that an INBOUND TCP 23764 is being block by my computer.
i just added that to the firewall exception and it work.
i should Wireshark it from the beginning.
thanks again for the replies.
