Okay tell me this… compare the performance of a Motorola haf4013 near the sharkfin in the Toyota 4Runner compared to that 1/4 wave in the dead center, and then compare that to the stock antenna.
Stock antenna inside the vehicle is going to perform worse that either of the two external antennas.
Likely you won't notice much of a difference between the other two mounted outside.
For full effect, you want 1/4 wavelength of uninterrupted ground plane under the external antenna, so 3" all the way around the base. I'd keep it spaced a foot or so away from the shark fin just to keep that from making it directional, and to keep it away from whatever RF noise might come from the GPS/Satellite/Cellular part of the antenna.
I see police vehicles with these Pctel and Motorola can antennas in my city
Yup, likely it will work fine for you. But the police vehicles having transmitters are going to be designed around some different things that you. They have requirements that the ERP (effective radiated power) of their radio (transmitter power output, minus feed line losses, multiplied by antenna gain) stays within the limitation of their license. Also, they are geared towards performance inside their area of jurisdiction with some extra added in. As a scanner/receiver user, you don't have the ERP limitation and the extra gain won't hurt.
But just looking at cost (like I said, if you haven't purchased the Motorola antenna) you will get similar performance out of the 1/4 wave antenna, or if you want the additional gain, try one of the 2 gain antennas I linked to.
