Wanting to know if it's the same size as the 396t. To see if my case for the 396t will fit the 396xt or not.
Same size:. To see if my case for the 396t will fit the 396xt or not.
Uniden Hard Leather Police Scanner Carrying Case | Scanner MasterWanting to know if it's the same size as the 396t. To see if my case for the 396t will fit the 396xt or not.
Yeah, that case is out of stock.I already have one.
Also, the displays, buttons, and speakers on the 2 scanners line up perfectly with each other.Wanting to know if it's the same size as the 396t. To see if my case for the 396t will fit the 396xt or not.
does the 396xt use the same programming cable as the 396t?Also, the displays, buttons, and speakers on the 2 scanners line up perfectly with each other.
I looked it up for ya'does the 396xt use the same programming cable as the 396t?
I think it is the hood causing the issue. Not sure if the eye holes are restricting vision, it is too tight and is restricting blood flow or restricting Oxygen flow.I looked it up for ya'
Uniden USB-1 Programming Cable (BC246/396/330/230/95/996/15/XT)
Uniden USB Cable - Programming cable for the following scanner: BCT15, BCT15X, BC95XLT, SC230, BC246T, BR330, BC346XT, BCD396T, BCD396XT. BCD996T, and BCD996XTwww.scannermaster.com
