Is this a bug?
D308
San Diego
Im seeing an issue when Ive got the groups file open and monitoring DSD+FL that when I edit a group number and add a name to it then save it, it unlocks a particular TG that was previously locked out. It is repeatable. In my case for the San Diego 700MHz system TG8194 which is the sanitation dept. it will always show unlocked after I edit the groups folder. No matter what TG I modify.
it’s not a big deal. Just something I’ve noticed.
Reconrider
Inside the Galaxy
Radio Galaxy
Sometimes DSD needs to be restarted.
As with all programs, some times they get glitchy after going for awhile.
D308
San Diego
Apparently so. It's no longer doing that.
Really enjoying it so far.
Any idea if it will listen to analog? Doesn't seem to do it here. Probably something I'm not doing right.
Reconrider
Inside the Galaxy
Radio Galaxy
You can listen to analog, but you need to just use fmp24.exe with an rtl dongle. I forget the exact way of doing it, but there should be a video on youtube of it
dave3825
Suffolk County NY
If FMPx is used to monitor analog channels,
select "Monitor Source Audio if No Sync and Signal Present" in the DSD+ input menu.
dave3825
Suffolk County NY
There is a squelch option also.
FMP24 -h Show help
Options:
-i0 Use first available RTL SDR device [-i0]
-i<num> Use RTL SDR device specified by <num> (1-255)
-i"<ser>" Use RTL SDR device with specified serial number string
-o<num> Output audio device (1-255) [-o1]
-o<linkID> Output audio DSD+ Link ID (256-65535)
-oT<port> Output audio TCP port (256-65535)
-g<num> RF gain (dB) [max]
-T<num> Enable/disable bias tee (0-1) [-T0]
-P<num> Frequency correction PPM value (-999.9-999.9) [-P0.0]
-a<num> Enable/disable auto center tuning (0-1) [-a1]
-q<num> Enable/disable squelch logic (0-1) [-q0]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial RF filter bandwidth (4, 7, 9.5, 12.5, 22) [-b7]
-b-<kHz> Set initial RF filter bandwidth and ignore hints from DSD+
-t<num> Initial RF filter set (standard or tight) [-t0]
-u<num> Enable/disable unlicensed spectrum display (0-1) [-u0]
-z<num> Show zoomed spectrum (0-1) [-z1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-e<num> Enable/disable extra CPU load to reduce I/Q dropouts [-e2]
-y<num> Select spectrum survey list file (0-999) [-y0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rc Role is trunk control/rest channel monitor
-rv Role is trunk voice channel monitor
Active keys:
0-9 . Enter set frequency
[/] select step size
Cursor </> step frequency
Ctrl Csr </> step frequency by 250 Hz
A toggle auto center tuning
D cycle audio demodulation mode
Q toggle squelch mode
U toggle unlicensed spectrum display mode
M toggle spectrum memory overlay
X reset spectrum memory
Z toggle spectrum zoom overlay
I select injection mode
b/B select RF bandpass filter
T select tight or standard RF bandpass filter set
t enable/disable bias tee
N select noise filter
L toggle lost I/Q data test mode
E toggle extra CPU load to reduce I/Q dropouts
Cursor ^/v adjust volume level
spacebar toggle muting
g/G adjust RF gain
p/P adjust PPM frequency correction
R toggle raw I/Q and FM demod recording
S start scanner mode or exit hold mode
Y start spectrum survey
C start trunk control/rest channel following mode
V start trunk voice channel following mode
? list active keys
Esc exit scanner/survey/CC/VC modes or exit program
D308
San Diego
Interesting..I was just wondering about that. It’s sitting there breaking squelch in between audio.
D308
San Diego
Have you or anyone used that GUI that’s available? I tried it but it won’t allow me to setup anything.
