Is this Basic, Enhanced or AES Encryption...DMR MOTOTRBO
jhsands
Texarkana, Arkansas
I suppose know the right people. A friend of mine ordered a dozen 7550e's and they were loaded, AES and all.. I was shocked when I read em and saw "AES 256" was activated in all of them. Didn't even know that was a feature.
Those were "special production" models that were supposedly made for the U.S. Government and that [apparently] fell through. Alvaro sold hundreds.
RRR
OFFLINE
USA
But then there are conflicting statements on here, stating the repeater doesn't have to be set up for encryption? (Which I always had understoff the repeater did in fact need to be set up for Enc, to be able to properly pass Enc.)
jhsands
Texarkana, Arkansas
I received the following last week. I'm guessing "AlgID=40" means enhanced privacy.
Freq=154.145000 DCC=0 RAS Enc Group call; TG=1 AlgID=40
  • Like
Reactions: RRR
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Setup as in you select the type(Basic or Enhanced or none) in a drop down menu. You don’t lad keys of any kind into the codeplug.
Even if you select ‘none’, the repeater WILL pass encrypted calls, it only means that you can have audio holes with weak signals.
  • Like
Reactions: RRR
exkalibur
York, Ontario
They weren't "special production" anything. Every XPR7550 (and 5550) out there right now is capable of AES256. It is in the firmware that sits in every radio. There's an entitlement ID that you need to activate via CPS in order to "unlock" AES (just like a flashcode on an APX radio unlocks features already in the firmware). The difference is, the required EID (HKVN4244A) is virtually impossible to order from Motorola. There are a few large customers in the US that Motorola has sold AES to and rumour has it, they're not as tight about it as they used to be.
RRR
OFFLINE
USA
What difference does it really make though?
Has anyone been able to break into "Enhanced encryption" on Mototrbo?
I think not.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I think not.
Considering it's only 40 bit, I would say it was probably compromised years ago.
kayn1n32008
Sector 001
I think not.
I can say unequivocally, 100%, RC4 is NOT secure. It is LESS secure than DES. Both by key space, and cipher strength.
It is garbage that ONLY keeps scanners from listening.
The only commercially available cipher that is still considered secure is AES.
hrh17
Not yet. There is a secret version of dsdplus that allows it though
Forts
Ontario, Canada
There was a video? I know there was video of a version of Linux DSD decoding basic privacy. But that was DSD, not DSD+.
