Isn't this dangerous?
fredva
Virginia/West Virginia
I'm not in the business and don't claim to be an expert, but the phrases "shall be provided" and "shall be capable" stand out to me. I'm not seeing "shall be used" or "must be used'. To me, it says the option must be available, especially when you combine it with the next statement regarding trunking systems being permitted.
crazyboy
NJ
Exactly! Not saying I agree with using a TRS on the fire ground but NFPA permits it.
KK4JUG
GA
"Shall be" is mandatory but that mandate is only to meet the NFPA standards. The NFPA notwithstanding, it still good practice. BUT, it's not law.
From the 2016 Text
9.3.1.5* Trunked system talk groups shall be permitted to be
used to provide on-scene tactical communications if desired by
the AHJ, and the provisions of9.3.1.3 and 9.3.1.4 shall still
apply.
Special Attention to 9.3.1.5
Thanks, the 2010 version has 9.3.1.5 talks about portable radios having capability in coverage areas without requiring external amplifiers.
Time for me to order an updated version.
Right.
And each jurisdiction chooses to adopt NFPA rules, and which version. Not uncommon for some areas to be a few years behind.
Voyager
From the 2016 Text
9.3.1.3* A communications radio channel, separate from the
radio dispatch channel, shall be provided for on-scene tactical
communications.
9.3.1.4* At a minimum, the tactical communications channel
identified in 9.3.1.3 shall be capable of operating in analog
simplex mode.
apply.
Just what we need - another debate over meaningless rules. 9.3.1.5 seems to not be possible while still following the others. There are no analog simplex talkgroups or analog simplex trunked systems.
For those who non't know, AHJ is Agency Having Jurisdiction.
Voyager
Have to remember technically they are not rules. They are recommended standards many places do not go by what the NFPA says or recommends.
That is true, but they carry the same legal weight as laws.
Congress makes laws. Agencies make regulations or standards. Regardless what the source is, if laws or standards or regulations are not followed, there is liability.
Even when you are not in an OSHA state, OSHA regulations will be the standard by which actions are judged with respect to occupational safety. If you are found to have violated an established standard, you are liable.
Breaking laws is worse than violating standards or regulations, but either will make you guilty in a court case. Again, regulations and standards carry the same weight as laws.
mule1075
Washington Pennsylvania
Not another debate Joe it is what is it is. Paid or volunteer this is how it is. We can debate this all day and you will lose. We are not policy makers but we think we are or should.
Voyager
I would not lose. My point is that 9.3.1.5 allows a case that does not exist with the current technology. That is a fact. Please cite a system that has trunked analog simplex if you wish to say I'm wrong.
mule1075
Joe you have to much time on your hands. We all know what should be done and what should not. Basically you think you should or know everything about it you do not. Let's agree to disagree I will put you on the list for the IAFF contract that you could tell us to better that I am negotiation.
crazyboy
NJ
"shall be provided" & "shall be capable" nothing says shall be used for all tactical communications. Just needs to be there in case needed.
Voyager
9.3.1.5 contains neither of those phrases.
simplex mode.
Same challenge: Please cite one system that uses analog simplex talkgroups.
ten13
ten13
The bottom line in all this is: do the people in the police/fire departments KNOW what kind of radio system they are buying when they sign the contract?
The answer, from my experience, is a resounding NO.
It's right for us, here, with varying amounts of hands-on radio knowledge to (rightfully) condemn the use of these systems for emergency operations, but unfortunately, we are not formally consulted, much less even asked about, the pros and cons of such a system.
The bosses who sign the contract ask a few rudimentary questions (primarily: how much?) while the Motorola rep nods in agreement with each question.
Then, when that poor guy in the cellar, lost with no air, tries to get on the radio for help and all he gets is a lot of chirping, everyone wants to know, how come? And Motorola's answer is (and I've seen this in some articles) that the system worked "as designed....". That covers Motorola from any liability and puts the entire liability on the Department who bought the system. In other words, the Department "knew....or should have known..." what they were buying, flaws and all.
But did they?
belvdr
simplex mode.
9.3.1.3 doesn’t specify anything about talkgroups. It simply says an alternate fire tac channel shall be provided.
KK4JUG
GA
When did the government give a private association the right to write laws? Quick answer: They didn't.
They are NOT laws and don't have the power or effect of laws. When was the last time someone was tried in a criminal court for violation of NFPA standards? I'm not talking about civil court where someone says a fire department should have followed the recommended procedures using the "best practice" theory.
Voyager
I said several posts ago only Congress can write laws. Agencies write standards or regulations which carry the same weight as laws in a court case.
Last time NFPA regs were used in a case? Not sure, but they are used very often to prove negligence.
crazyboy
NJ
simplex mode.
You’re proving my point and you don’t even realize it! At this point we’re just beating a dead horse though, we both agree that using off system simplex frequencies is the way to go. We will just have to disagree at the interpretation if the standards.
Voyager
The original point in this thread is about using TGs. (is using TGs dangerous?)
The combination of 9.3.1.3 and 9.3.1.4 seem to create conditions which do not allow use of TGs since no systems exist AFAIK that use TGs on analog, simplex, channels.
crazyboy
NJ
Agree, NFPA WILL come up in a civil suit if something happens!
belvdr
It doesn’t state that TGs should not be used. It says an alternate channel should be provided and, at a minimum, be analog simplex. 9.3.1.5 clarifies that to state that TGs are permitted.
Don’t read into it; take it at face value.
