No changeI wonder if it is simply because you don’t have the equal sign in there
—crypt-behavior=0
—crypt-behavior=0
No change
Would it be more of help if I sent you an raw grab so you can test on your side?That’s unfortunate. I’m sorry, but I think I have exhausted. Anything I could think of. I swear the file contents looks fine to me.
KeyID: 0070
Key: 3409B4357A
Maybe they need to be entered as:
KeyID: 112
Key: 223501104506
Alright guys, no clue why it's working, but seems like the missing '=' sign was what made it work.I wonder if it is simply because you don’t have the equal sign in there
—crypt-behavior=0
I had it there before and it didn't work. So not sure why all of a sudden adding it a second time make it work - either way, glad it works finallyGlad you got it working... The parameter syntax is documented in the README.md file.
--crypt-behavior=CRYPT_BEHAVIOR
encrypted traffic behavior: 0=allow, 1=silence, 2=skip
All part of the hobby haha. Frustration leads to figuring it outI can only imagine the frustration. Trust me I’ve been there and done that kind of thing many times. Glad you got it working.
maybe you can help with curses. I'm not sure what it's suppose to do, but mine does nothing. can you screenshot or explain what it actually is?Glad you got it working... The parameter syntax is documented in the README.md file.
keys.json
"0x0001": {"algid": "0xaa", "key": [ "0x70", "0x70", "0x70", "0x70", "0x70" ]},
"0x0003": {"algid": "0xaa", "key": [ "0x70", "0x70", "0x70", "0x70", "0x70" ]},
"0x1b50": {"algid": "0xaa", "key": [ "0x12", "0x34", "0x56", "0x78", "0x90" ]},
"0x1850": {"algid": "0xaa", "key": [ "0x62", "0x23", "0x96", "0x31", "0x04" ]},
"0x3131": {"algid": "0xaa", "key": [ "0x31", "0x31", "0x31", "0x31", "0x31" ]}
I enable 'curses' on rx.py and it didn't do anything on a p25 conventional system. That's what threw me off. On a trunked system it works great, thank youCurses is terminal control library used in Linux to provide a Text User Interface (TUI). Basically, you're using the curses TUI whenever you
execute (run) op25 from the command prompt. IE: ./rx.py --args "rtl" --gains 'lna:36' -S 960000 ... Optionally, op25 can be run using the
HTTP Console interface. IE: /rx.py --args "rtl" --gains 'lna:36' -S 960000 -l http:0.0.0.0:8080 ...
Execution via the curses interface requires that you maintain an open terminal while in operation to provide a destination or termination
for the standard output (stdout) stream. If you desire to run op25 as a system service (automatically upon startup) then you'd make use of
the http console option such that program output would be directed to the python waitress (web interface).
When running multi_rx.py, you configure the terminal type from within the json file whereby you comment "#" out one or the other of the
two terminal types as desired for your use application.
"terminal": {
"module": "terminal.py",
"#terminal_type": "curses",
"terminal_type": "http:0.0.0.0:8080",
"terminal_timeout": 5.0,
I had everything correct except the missing equal sign in the crypt-behaviour argument. Appreciate the replyThis is the keys file format:
Code:keys.json { "0x0001": {"algid": "0xaa", "key": [ "0x70", "0x70", "0x70", "0x70", "0x70" ]}, "0x0003": {"algid": "0xaa", "key": [ "0x70", "0x70", "0x70", "0x70", "0x70" ]}, "0x1b50": {"algid": "0xaa", "key": [ "0x12", "0x34", "0x56", "0x78", "0x90" ]}, "0x1850": {"algid": "0xaa", "key": [ "0x62", "0x23", "0x96", "0x31", "0x04" ]}, "0x3131": {"algid": "0xaa", "key": [ "0x31", "0x31", "0x31", "0x31", "0x31" ]} }
Do either of you or anybody have a different UI layout for the local site? I'm dog poop at html/css
Make's a lot of sense with lack of information. I don't typically look at it anyway - I like to set it and forget it until some audio pops up but looking to make sure it's still going correctly.There's limited curses/http I/O when configured to receive a conventional system in that op25 was primarily written to receive P25 TRS.
Here's a recent thread in reference to this aspect of op25 internal data sources.
Appreciate the reply.P25 Conventional does not show any activity in the UI because the UI relies on data fed from the trunking module, which of course isn't active when you're in a non-trunked environment.
Yes. My approach uses Liquidsoap with op25 to process the audio where I derive local speaker audio, private Icecast streaming, and recording of mp3 files (archives) that are accessible via a collocated apache2 webserver.is it possible to output the audio into files? ...
If you don't mind, can you explain how you did it? I've looked yesterday quiet a bit and found nothing when trying to setup the liq fileYes. My approach uses Liquidsoap with op25 to process the audio where I derive local speaker audio, private Icecast streaming, and recording of mp3 files (archives) that are accessible via a collocated apache2 webserver.
Here's a screen capture of the current day hourly mp3 audio archive files.
#!/usr/bin/liquidsoap
# Example liquidsoap streaming from op25 to icecast
# (c) 2019-2021 gnorbury@bondcar.com, wllmbecks@gmail.com
set("log.stdout", true)
set("log.file", false)
set("log.level", 3)
# Make the native sample rate compatible with op25
set("frame.audio.samplerate", 8000)
input = input.external.rawaudio(buffer=0.25, channels=2, samplerate=8000, restart_on_error=false, "./audio.py -u 23450 -x 1.35 -s")
# Consider increasing the buffer value on slow systems such as RPi3. e.g. buffer=0.25
# Longer buffer results in less choppy audio but at the expense of increased latency.
# OPTIONAL AUDIO SIGNAL PROCESSING BLOCKS
# Uncomment to enable
# High pass filter
#input = filter.iir.butterworth.high(frequency = 200.0, order = 4, input)
# Low pass filter
#input = filter.iir.butterworth.low(frequency = 3250.0, order = 4, input)
# Compression
input = compress(input, attack = 15.0, gain = 2.0, knee = 1.0, ratio = 3.0, release = 60.0, threshold = -24.0)
# Normalization
input = normalize(input, gain_max = 6.0, gain_min = -6.0, target = -16.0, threshold = -40.0)
# Optimize mp3 audio recording level
mp3_audio = amplify(0.65,input)
# Create infallible local speaker and streaming audio
input_safe = mksafe(input)
# LOCAL AUDIO OUTPUT
# Uncomment the appropriate line below to enable local sound
# Default audio subsystem
#out (input)
# PulseAudio
#output.pulseaudio(input)
# ALSA
output.alsa(input_safe)
# Dump mp3 audio files to Apache web server
output.file(%mp3(stereo=true), "/var/www/html/op25/MPSCS-%Y-%m-%d/hour-%H.mp3", mp3_audio, fallible=true, append=true,
reopen_when={0m})
# ICECAST STREAMING
# Uncomment to enable output to an icecast server
# Change the "host", "password", and "mount" strings appropriately first!
# For metadata to work properly, the host address given here MUST MATCH the address in op25's meta.json file
output.icecast(%mp3(bitrate=16, samplerate=22050, stereo=false), description="op25", genre="Public Safety",
url="", fallible=false, icy_metadata="false", host="localhost", port=8000, mount="op25", password="hackme", mean(input_safe))
