issues with programming ht 1000
Jasonk1
I tried to program my ht 1000 with a serial port cable with an FTDI USB adapter attached to it on my Mac running Windows 10 via a virtual machine with Dosbox (I have programmed my 750's and 1250's on this VM with CPS, and it works perfectly). When I try to read the radio, I keep getting the error message, "rib port communication unsuccessful." I tried on five ht 1000's and also attempted this on my old Windows XP computer. I plugged the programming cable into the serial port, and I get the same error message. I also tried with the FTDI adapter, and I get the same message. Does anybody have any idea why this is not working?
cmjonesinc
I've never had any luck with any modern computer or ever using a dos box. You'll need an old computer running real dos (dos booted from usb is fine) and likely a serial cable. Doubt you'll find a usb to serial adapter that will play with dos. Even my old cf19 mk3 doesn't play well in true dos with a serial cable. My cf18 works great. Those old things can be a headache. If you don't mind paying shipping I gladly program them for you.
Jasonk1
Thank you! Booting Dos from USB works!
Find an old Windows machine running no more than Windoze XP.
Download "Rufus", it's a dos emulator.
I have that on a USB thumb drive and set up the old laptop to try booting off USB as first choice. If I need to use the older HT1000 software, I just plug in the Rufus stick and boot up into that. You'll need a serial connection off the PC, never had any luck with DOS and USB.
Jasonk1
Thank you, this works.
cmjonesinc
Glad you got it going. If you have any other issues, just ask. I've programmed a pile of those things.
